Floating Candle.
 by gert1000
video Floating Candle.
Easy vay to make very well balanced floating candles.
SIRJAMES09 says: Oct 31, 2011. 9:28 AM
someone said you should wear gloves when taking this light bulb apart....
I agree 100%...PLUS, I think you should also have some goggles or safety glasses on too....or anything else that will protect your eyes.
there is a soldered joint on the side of the bulb....some times, I stress SOME TIMES, if you desolder that spot, plus the spot on the very bottom of the bulb, the bulb will come apart easier. it still will not be easy, & the bulb can still break, but SOME TIMES it comes apart easier.
Q: there is this stuff called "Goo Gone", the cost of it is like 4000 gallons for a dollar (figuratively speaking)....
I wonder if that would help to clean the inside of the bulb??
Goo Gone is what allows you to take stickers off bottles & such...it dissolves the glue that holds the labels on....
ironsmiter says: Feb 25, 2008. 4:42 PM
VERY important note.... that was an electric stove. Do NOT do that single pot melting over a gas burner... may also want to use some gloves when removing the bulb glass. Otherwise.. very nice idea, and well executed.(were those fishing weights on the wicks?)
w00ty32 in reply to ironsmiterMar 11, 2008. 10:35 PM
Why can't you use a gas burner? Just curiosity, as i have a electric stove anyway.
SIRJAMES09 in reply to w00ty32Oct 31, 2011. 9:14 AM
candle wax + gas stove(IE:flame) = house fire.
ironsmiter in reply to w00ty32Mar 12, 2008. 1:35 AM
Saftey first.. I SHOULD have said ... ALWAYS USE A DOUBLE BOILER. wow..ok... everyone breath deep. we got here in time. Parafin (what mostly makes up candle wax) is highly flamable. that's why it makes such good candles. The flame of pure parafin burning is INVISIBLE to the naked eye. by melting candles over an open flame, you create the ideal circumstances for the flames to go WHOOSH, and burn you quite badly and you may never even realize why! (unless you just read this :-) The average candle wax has a flash point of 375-400 degrees. once it reaches this tempature, it will self-ignite, open flame, or no open flame. And your only warning will be that plesant smell of burning hair, as your flesh begins to turn into people-steak. The trick is... open gas flames are usually in excess of a thousand degrees. plenty to light off the fumes. Now.. as to why the double boiler is so important. Water boils at an average of 215F(yeah, yeah, i know it's "really" 212) This means, as long as there is still water, in the double boiler setup.... the wax will never exceed 250 degree F. WELL below the flash point. Now, it's POSSIBLE to regulate an electric element to maintain a temp that's lower than the flashpoint... but it's so simple to be safe, do you REALLY want to chance it? :-) I add that last paragraph because there ARE applications where direct heating by electrical element is used.. and safely. Almost any wax-injection molding setup will have a variable-temp melting pot. But if you had to ask why you can't use a gas stove... you've got a ways to go before you safely design your own electric melting pots.
BellaStella7 in reply to ironsmiterMar 25, 2009. 9:28 PM
lol thank you so much. I could have either died or burned my eyebrows and eyelashes off as well as half the hair on my head! :) I was seriously going to try this on my gas stove.. Geez... Thank you so much!
carpespasm in reply to ironsmiterJun 17, 2008. 6:20 PM
Very good things to consider. Thanks for spreading the knowledge.
gert1000 (author) in reply to ironsmiterFeb 26, 2008. 4:33 AM
Yes, thank you a lot! Only electric stove and gloves only recommended, cause its so thin glass .... but safety first. fishing weights are to keep the string straight and yo give some extra balance for the candle....
and-reas says: Dec 3, 2009. 8:57 AM
I was thinking about leaving the glass on, and putting the whole bulb in a kind of stand, but I'm afraid the glass won't hold and break.
SIRJAMES09 in reply to and-reasOct 31, 2011. 8:50 AM
and a candle gets hotter I think that that glass can handle....which means it may break or shatter....
teslafan100 says: Feb 27, 2010. 7:34 AM
cool
Zaphod Beeblebrox says: Aug 16, 2009. 3:31 PM
one word:POOL
Zaphod Beeblebrox in reply to Zaphod BeeblebroxAug 16, 2009. 3:53 PM
other word:BATHTUB
rachel2710 says: Jul 19, 2009. 2:58 PM
I've melted wax in a pan directly on a gas stove with no problems. Just make sure you take the pan off the heat several times for a few minutes to give it a chance to cool. Of course, use your common sense, I don't want to be responsible for lost hair (or worse!!).
naruto the ninja13 says: Jun 4, 2009. 7:03 AM
wered you get the awesome blue matches
crayzclown1 says: Apr 17, 2009. 9:43 PM
cool, faved. ill have to try this sometime.
ansanma says: Dec 14, 2008. 3:17 PM
I've adapted your idea using empty eggs and here it is the result. Thank you!
dodo91 in reply to ansanmaMar 3, 2009. 4:59 PM
you've gotta remember, eggs arent round, theyre oval. they might tilt when you put them in water. did you use it in water yet?
ansanma in reply to dodo91Mar 28, 2009. 2:05 PM
In fact, the candle has not the whole egg shape, so the top part is not present and it doesn't tilt... Believe me, here you have the proof:
dodo91 in reply to ansanmaMar 31, 2009. 4:42 PM
thanks!
esplonky says: Feb 6, 2009. 6:53 PM
SO romantic
IW5 Industries says: Feb 4, 2009. 3:02 PM
but what about when the wax melts over the candle into the water?
WatskeBart says: Apr 30, 2008. 4:37 AM
How did you break the sockets from the bulb? I screwed up several bulbs now :(
junits15 in reply to WatskeBartJan 6, 2009. 1:42 PM
here is the safest way that i know of, chip through the black glass near the bottom, then break the filiment holder withe the metal is still on the bulb, this gives a cleaner cut. once that is done peel off the metal and clean the bulb.
RetroTechno in reply to WatskeBartDec 4, 2008. 5:06 PM
A carbide scribe works well too.
themasterpyro in reply to WatskeBartJun 1, 2008. 7:21 PM
i used a sharp file very carefully. not foolproof but it works oftne enough. i fill mine with explosives :)
Gun Maniac in reply to themasterpyroOct 30, 2009. 12:25 PM
I use old bulbs that have been used a lot and therefore the bayonet cap has expanded and contracted due to heat weakening the joints, all i do is hold the glass in a towel and twist the cap
freakinslop says: Oct 9, 2008. 6:03 PM
o my god this is amazing! 5*s!!!!!!!
junits15 says: Sep 28, 2008. 4:49 PM
cool! but you should realy wear gloves when remving the glass
dontwealllovebuda92 says: Sep 14, 2008. 6:10 PM
hey my names casey to but anyway cool!!!!!
casey321b says: Sep 8, 2008. 8:47 PM
gives me an idea. check soon for an instructable. i dont want anybody taking it so youl have to look at my page to see when it comes
All4Shrimp says: Jul 23, 2008. 10:45 AM
4.5 man! Really nice!
ac1D says: Feb 25, 2008. 3:52 PM
cool! how many water you put with the candle ?
gert1000 (author) in reply to ac1DFeb 26, 2008. 4:30 AM
water? did you meant how much water in the bowl? its enough water, when candle can float freely, without touching the bottom of the bowl....
ac1D in reply to gert1000Mar 3, 2008. 12:01 AM
no, sorry i tough there was water in the thing you use to melt the candle in..
carpespasm in reply to ac1DJun 17, 2008. 6:17 PM
Liquid paraffin (candle wax) is clear. It goes back to translucent when it cools off. That's melted liquid wax in the video.
ac1D in reply to carpespasmJun 18, 2008. 2:56 PM
Yeah thanks, i have noticed right after :)
kgtateddy in reply to ac1DApr 24, 2008. 6:53 PM
by water you mean melted candle?
hootieferu says: Jun 14, 2008. 10:43 PM
this might be an oversight, but the egg cartons you used to steady the light bulbs should technically be able to serve as the molds for floating candles, right? especially if they were styrofoam or you could similarly use the cardboard one and line it with foil or plastic wrap. or better yet use cupcake liner tins (and the candles might look like peanut butter cups, yum). what I am trying to get at here is just be careful if you decide to use light bulbs and that there might be alternatives if you like this idea (which is pretty good i must say!)
soul_jahz_united says: May 6, 2008. 5:23 PM
yea man, the video was really good, also tanks to ironsmiter for making sure we don't die trying to make yellow floating candles.
RONALD1645 says: Mar 4, 2008. 7:52 AM
VERY WELL DONE VIDEO THANKS
GorillazMiko says: Feb 25, 2008. 4:13 PM
Cool! That looks really nice, and easy to do too. +1 rating.
gert1000 (author) in reply to GorillazMikoFeb 26, 2008. 4:34 AM
Thanks for rating and I'm glad that you liked ! :-)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
