3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Floating Candle.
video Floating Candle.
Easy vay to make very well balanced floating candles.
43 comments
1-40 of 43next »
Oct 31, 2011. 9:28 AMSIRJAMES09 says:
someone said you should wear gloves when taking this light bulb apart....
I agree 100%...PLUS, I think you should also have some goggles or safety glasses on too....or anything else that will protect your eyes.
there is a soldered joint on the side of the bulb....some times, I stress SOME TIMES, if you desolder that spot, plus the spot on the very bottom of the bulb, the bulb will come apart easier. it still will not be easy, & the bulb can still break, but SOME TIMES it comes apart easier.
Q: there is this stuff called "Goo Gone", the cost of it is like 4000 gallons for a dollar (figuratively speaking)....
I wonder if that would help to clean the inside of the bulb??
Goo Gone is what allows you to take stickers off bottles & such...it dissolves the glue that holds the labels on....
Feb 25, 2008. 4:42 PMironsmiter says:
VERY important note.... that was an electric stove. Do NOT do that single pot melting over a gas burner... may also want to use some gloves when removing the bulb glass. Otherwise.. very nice idea, and well executed.(were those fishing weights on the wicks?)
Mar 11, 2008. 10:35 PMw00ty32 says:
Why can't you use a gas burner? Just curiosity, as i have a electric stove anyway.
Oct 31, 2011. 9:14 AMSIRJAMES09 says:
candle wax + gas stove(IE:flame) = house fire.
Mar 12, 2008. 1:35 AMironsmiter says:
Saftey first.. I SHOULD have said ... ALWAYS USE A DOUBLE BOILER. wow..ok... everyone breath deep. we got here in time. Parafin (what mostly makes up candle wax) is highly flamable. that's why it makes such good candles. The flame of pure parafin burning is INVISIBLE to the naked eye. by melting candles over an open flame, you create the ideal circumstances for the flames to go WHOOSH, and burn you quite badly and you may never even realize why! (unless you just read this :-) The average candle wax has a flash point of 375-400 degrees. once it reaches this tempature, it will self-ignite, open flame, or no open flame. And your only warning will be that plesant smell of burning hair, as your flesh begins to turn into people-steak. The trick is... open gas flames are usually in excess of a thousand degrees. plenty to light off the fumes. Now.. as to why the double boiler is so important. Water boils at an average of 215F(yeah, yeah, i know it's "really" 212) This means, as long as there is still water, in the double boiler setup.... the wax will never exceed 250 degree F. WELL below the flash point. Now, it's POSSIBLE to regulate an electric element to maintain a temp that's lower than the flashpoint... but it's so simple to be safe, do you REALLY want to chance it? :-) I add that last paragraph because there ARE applications where direct heating by electrical element is used.. and safely. Almost any wax-injection molding setup will have a variable-temp melting pot. But if you had to ask why you can't use a gas stove... you've got a ways to go before you safely design your own electric melting pots.
Mar 25, 2009. 9:28 PMBellaStella7 says:
lol thank you so much. I could have either died or burned my eyebrows and eyelashes off as well as half the hair on my head! :) I was seriously going to try this on my gas stove.. Geez... Thank you so much!
Jun 17, 2008. 6:20 PMcarpespasm says:
Very good things to consider. Thanks for spreading the knowledge.
Dec 3, 2009. 8:57 AMand-reas says:
I was thinking about leaving the glass on, and putting the whole bulb in a kind of stand, but I'm afraid the glass won't hold and break.
Oct 31, 2011. 8:50 AMSIRJAMES09 says:
and a candle gets hotter I think that that glass can handle....which means it may break or shatter....
Feb 27, 2010. 7:34 AMteslafan100 says:
cool
Aug 16, 2009. 3:31 PMZaphod Beeblebrox says:
one word:POOL
Aug 16, 2009. 3:53 PMZaphod Beeblebrox says:
other word:BATHTUB
Jul 19, 2009. 2:58 PMrachel2710 says:
I've melted wax in a pan directly on a gas stove with no problems. Just make sure you take the pan off the heat several times for a few minutes to give it a chance to cool. Of course, use your common sense, I don't want to be responsible for lost hair (or worse!!).
Jun 4, 2009. 7:03 AMnaruto the ninja13 says:
wered you get the awesome blue matches
Apr 17, 2009. 9:43 PMcrayzclown1 says:
cool, faved. ill have to try this sometime.
Dec 14, 2008. 3:17 PMansanma says:
I've adapted your idea using empty eggs and here it is the result. Thank you!
Mar 3, 2009. 4:59 PMdodo91 says:
you've gotta remember, eggs arent round, theyre oval. they might tilt when you put them in water. did you use it in water yet?
Mar 28, 2009. 2:05 PMansanma says:
In fact, the candle has not the whole egg shape, so the top part is not present and it doesn't tilt... Believe me, here you have the proof:
Mar 31, 2009. 4:42 PMdodo91 says:
thanks!
Feb 6, 2009. 6:53 PMesplonky says:
SO romantic
Feb 4, 2009. 3:02 PMIW5 Industries says:
but what about when the wax melts over the candle into the water?
Apr 30, 2008. 4:37 AMWatskeBart says:
How did you break the sockets from the bulb? I screwed up several bulbs now :(
Jan 6, 2009. 1:42 PMjunits15 says:
here is the safest way that i know of, chip through the black glass near the bottom, then break the filiment holder withe the metal is still on the bulb, this gives a cleaner cut. once that is done peel off the metal and clean the bulb.
Dec 4, 2008. 5:06 PMRetroTechno says:
A carbide scribe works well too.
Jun 1, 2008. 7:21 PMthemasterpyro says:
i used a sharp file very carefully. not foolproof but it works oftne enough. i fill mine with explosives :)
Oct 30, 2009. 12:25 PMGun Maniac says:
I use old bulbs that have been used a lot and therefore the bayonet cap has expanded and contracted due to heat weakening the joints, all i do is hold the glass in a towel and twist the cap
Oct 9, 2008. 6:03 PMfreakinslop says:
o my god this is amazing! 5*s!!!!!!!
Sep 28, 2008. 4:49 PMjunits15 says:
cool! but you should realy wear gloves when remving the glass
Sep 14, 2008. 6:10 PMdontwealllovebuda92 says:
hey my names casey to but anyway cool!!!!!
Sep 8, 2008. 8:47 PMcasey321b says:
gives me an idea. check soon for an instructable. i dont want anybody taking it so youl have to look at my page to see when it comes
Jul 23, 2008. 10:45 AMAll4Shrimp says:
4.5 man! Really nice!
Feb 25, 2008. 3:52 PMac1D says:
cool! how many water you put with the candle ?
Mar 3, 2008. 12:01 AMac1D says:
no, sorry i tough there was water in the thing you use to melt the candle in..
Jun 17, 2008. 6:17 PMcarpespasm says:
Liquid paraffin (candle wax) is clear. It goes back to translucent when it cools off. That's melted liquid wax in the video.
Jun 18, 2008. 2:56 PMac1D says:
Yeah thanks, i have noticed right after :)
Apr 24, 2008. 6:53 PMkgtateddy says:
by water you mean melted candle?
Jun 14, 2008. 10:43 PMhootieferu says:
this might be an oversight, but the egg cartons you used to steady the light bulbs should technically be able to serve as the molds for floating candles, right? especially if they were styrofoam or you could similarly use the cardboard one and line it with foil or plastic wrap. or better yet use cupcake liner tins (and the candles might look like peanut butter cups, yum). what I am trying to get at here is just be careful if you decide to use light bulbs and that there might be alternatives if you like this idea (which is pretty good i must say!)
May 6, 2008. 5:23 PMsoul_jahz_united says:
yea man, the video was really good, also tanks to ironsmiter for making sure we don't die trying to make yellow floating candles.
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:gert1000
