3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Floating Dock with Barrels (UPDATED)
Step 2Support the Frame
Support the Frame
Now that you have the basic shape we need to add supports.
Measure out the middle of the square and place a 2x4" support there.
The remaining bottom layer pieces are playing two roles. They are supporting the frame as well as holding the barrels against the dock and preventing them from pushing up against the decking. Place two of the boards as the picture shows and lay a barrel on top. Shift the boards around until you get the barrel sitting nicely in between the boards without touching the ground but also fitting nicely around the curve in the barrel. Mark that point, screw them in and do the same to the other side.
Now the top layer of supports that run perpendicular to the rest also have two jobs. The provide the cross support and keep the barrels from moving back and forth while in the water. So once again place your barrels on the bottom supports and measure where the barrels end. Place your top layer supports here and screw them in.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:pilx
I worry too much.
