Introduction: Floating LED Butterflies
Picture of Floating LED Butterflies
This is my first Instructable, unfortunatly i seem to have lost some of the images that i took of the steps taken how ever this is how it was made.
I wanted a night light for my 2 year old daughter but something different. The end result was better then i hoped for , a little on the bright side but none the less it put a smile on her face and thats all that counts at the end of the day.
The whole process took about a month and a lot of trial and error as im not electrical minded.
Thanks in advance for looking.
Step 1: Steps Taken
Picture of Steps Taken
Step 1 , 100x 2mm Steel butterflies lasercut ( i wanted something that would last ) and painted
Step 2 , drilled holes in the center and put verious length bolts and nuts
Step 3 , I had a old door lying around and thought it would be perfect as i could remove the back side and the cardboard mesh inside to conceal the wires
Step 4 , I used a cardboard box to draw the layout and the placement for the butterflies
Step 5 , Drill the hole for the butterflies and the 5mm hole for the LEDs and attach the buterflies to the door.
Step 6 , Solder the resistors and 5mm LEDs for each butterfly so that i can connect direct to a 12volt adaptor
Step 7 , Insert the LEDs into the 5 mm hole that was drilled and connect them to the 12volt adaptor.
Step 8 , Mount the door to the wall and plug in the lights.
Step 2:
tionnalove223 (author)2015-11-20
that is so cute i wanna make one of them for my little sister
Thanks, if you need and info i'd be more than happy to help
seamster (author)2015-11-18
This turned out really cool! Does each butterfly have it's own LED under it?
Weaponzx007 (author)seamster2015-11-18
Thanks, yes each butterfly has a LED.
About This Instructable
425views
18favorites
License:
More by Weaponzx007:Acoustic Guitar CutawayFloating LED butterflies
Add instructable to:
