Floating Plant Basket
7,059
19
Posted
Introduction: Floating Plant Basket
Floating plants are a wonderful addition to fish ponds. With few supplies you can turn a simple water plant basket into a floating one.
Step 1: Materials and Tools
The only tool you need is scissors. And the material we'll use for the floating ring is pipe insulation. We'll also need heavy duty cable tie straps.
For the basket, I've chosen one designed for water loving plants. It's perforations allow for water to freely move through and for roots to grow outside of the basket.
Step 2: Attaching the Insulation
Using the cable straps, create very loose rings around the basket at the top.Space them out every two inches or so.
Now start threading the insulation. We want the insulation to be firmly attached, but not compressed or squeezed so that it's kinked or collapsed. Tighten the straps as you go.
When you get to the end, cut the insulation and trim it so that it's a clean joint. Use multiple cable straps to hold the ends in place.
Step 3: Add Plants and Float
Now that you're done, you can add you plants and float them in your pond.
What kinds of plants? Look for plants that like constant moisture. Many rushes and sedge fit this. Corkscrew rush is an attractive one that thrives and handles harsh winters, too. The roots and leaves that sit in the water will provide a good source of food for your fish.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    2 Comments
    Cool idea! Thanks for sharing this!
    I was just thinking about constructing some islands but the commercial ones are way too expensive. I had not thought about this material yet. Thanks for the tip
