Introduction: Floating Soda Bottle Decoration
Express your passion for any soda (for whatever reason) by making a hang-able soda bottle decoration.
Materials/Tools:
1- Any soda bottle of any size.
2- Paint (make sure it's the same color as the soda) - spray paint works /gloss is preferred.
3- String or yarn
4- Sharp object for poking a hole in the bottlecap
5- Blow dryer (optional)
6- Any means of hanging the string to your ceiling. I used a large staple.
Steps:
1- Carefully remove the wrapper using a heat function on the blow dryer to loosen the adhesive.
2- Poke a hole in the center of the bottlecap using the sharp object.
3- Poke the string/yarn through the hole. (use the sharp thing if you have to)
4- Tie a knot in the string on the inside end of the bottlecap. Make sure the knot is larger than the hole.
5- Paint the bottle and let it dry.
6- Wrap the wrapper back around the bottle in the correct spot, using the adhesive on the inside of the wrapper.
7- Screw the bottlecap back on the bottle and hang it to your ceiling (or anything else you want to hang it on)
8- Enjoy your floating soda bottle.
