Floating Spice Shelves
7,901
312
Posted in HomeOrganizing
Introduction: Floating Spice Shelves
About: Teacher. Climber. Craftsman.
I built these walnut spice shelves to make use of a small bit of wall between our kitchen nook and kitchen doorway. The 4 shelves are cut from a single piece of walnut, then each shelf is recessed with a router. The shelves are attached to the wall with pocket holes.
Supplies:
Shelf wood (I used walnut)
Scrap wood for the routing jig (I used some leftover baltic birch and MDF)
Table saw
Router with 3/4 inch straight router bit
Kreg Mini Pocket-Hole Jig
1/8 inch toggle bolts (for drywall)
Pocket-hole screws (for studs)
Arm-R-Seal Urethane Topcoat
Step 1: Shelf Blanks and Routing Jig
Shelf Blanks
I cut four blocks of wood from a single piece of walnut. Each block is 17 inches long, 1.25 inches tall, and 3 inches wide. Depending on your space, you could use any variety of wood, cut to a dimension that best meets your need.
Routing Jig
I framed up the routing jig with 3/4 inch baltic birch strips that were 4 inches wide. I used pocket hole joints for this. On top, I added strips of MDF for the router's base plate to ride against. With careful measurements I set the guides to leave the sides of the shelf 3/4 inches thick, and the front edge 1/2 inch thick. The placement of these guides depends on the router you are using, and the dimensions of your shelves.
-Because of the depth of the recess (1 inch), a flush trim router bit or guide bushing seemed more challenging than using the base plate as a guide.
I added wood beneath the jig so that the top surface would be flush with the shelf blank when sitting on a work bench.
I clamped the jig to my work bench and shimmed in the shelf blanks so that they would not move.
I routed each shelf in four layers, removing a depth of .25 inches each time. The total depth is 1 inch. I stopped regularly to vacuum, as the router is removing a lot of wood.
Step 2: Pocket Holes
On scrap wood, I experimented with the placement of the Kreg Jig. I wanted the holes centered left and right, and as centered as possible up and down. The set up instructions that come with this jig aren't very accurate, so I find some experimenting is important for perfect holes.
I set up the stop collar on the drill bit so that the 1/8 inch tip of the stepped drill bit barely came out the back of the shelves. This ensured that the bolts wouldn't rip out the back once installed.
Step 3: Finish and Install
I sanded the shelves with 220 grit sandpaper, then used General Finishes Arm-R-Seal Satin. I find the Arm-R-Seal is easy to use, and looks great. I applied 3 coats, sanding with steal wool between coats.
I was able to align my shelves so that one side could be screwed directly into a stud. I used the Kreg pocket-hole screws for these. The other side was not on a stud, so I used the 1/8inch toggle bolts into the drywall. For spices, these shelves are plenty strong, and would be strong enough with just toggle bolts in drywall only.
Step 4: Bonus
With some of the leftover walnut, I made a matching kitchen spoon.
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    3 Comments
    These shelves are gorgeous. I need to make some just like yours!
    And a side note, this is the perfect way to do an after-the-fact instructable! Excellently done on the documentation. Hope we see more from you soon. :)
    Very attractive final product! Thanks for sharing!
    Those shelves look amazing! I think I'll make some in the future when I can.
