This is a fun and chic little vanity that can be inexpensive if you know where to shop! With this antique style making such a resurgence in popularity, you can really 'go for baroque' with this project!
Step 1: Find an old furniture castoff.
We enjoy re-purposing and saw this nightstand for sale on some online classifieds for $10. It was looking pretty beat up, but we thought it had good bones and saw it had potential, so picked it up.
Let your imagination go wild! If you've got room for two sinks, pick up a swank, 60's console and upcycle it! They are probably long enough to house two sinks with lots of counter space to spare and a modern shape. A nightstand or end table would work great for a tighter space. Our wee ensuite bath didn't have enough room to swing a cat, so this teeny table was perfect.
Other materials needed for this project: vessel sink, faucet, drill, random screwdrivers & hardware bits, sandpaper, spraypaint, some scrap 2x4...I think that's it. You should be able to re-use your plumbing and supply lines if you aren't changing the height of your sink.
Step 2: Sand well before painting.
Remove the handles and sand with a rough grit sandpaper to lose the shiny, lacquered finish. Finish up with a finer grit sandpaper. Be sure to get in all the nooks and crannies and wipe down well afterwards with a slightly damp cloth. They say the quality of sanding job you do affects the final outcome, and they are right!
Step 3: Remove drawer fronts & hardware.
Remove drawer fronts from rest of drawer.  I just used a hammer and banged on the inside of the drawer front away from the rest of the drawer. It was only held by small nails, so this step was a piece of cake.  You can discard the drawer innards, as your sink plumbing will be tucked away underneath, and there won't be room for working drawers.
In a well-ventilated area, spray paint your handles, drawer fronts and vanity (in this case nightstand).  I used 3 cans of paint to do a thorough job and it left a glossy surface with excellent coverage. It also made a difference that I was painting a dark piece of furniture white...had I been painting an already white piece of furniture, I may have only needed one can. Your mileage may  vary.
Step 4: Mark and drill out your plumbing holes.
We placed our vessel sink on the vanity where we wanted it...slightly off-centre. With a pen or pencil, draw a circle through your drain hole, in addition to marking the holes for your faucet, including hot and cold water. Measure twice, cut once, you can't undo this!  Carefully drill holes in the top of your vanity, making sure you don't scuff up your spanky new paint job.
 Tip: don't empty the spray can onto your project, thinking you're done painting. You may need to do a touch up and you don't want to have to buy a whole new can just for a shot here and there.
Step 5: Mount vanity & hook up plumbing.
You will need to find studs in the wall to mount your vanity to, especially if you do a floating vanity.  We mounted a 2x4 horizontally and rested the vanity on it, then attached with brackets that strapped over the underneath side of the vanity and 2x4.  It is rock solid. If you have a decent junk drawer (or 4), you should be able to find some configuration that will get that puppy hung up for you!
 If your vanity sits on the floor (as it would if you've repurposed an old dresser), locating studs in the wall is not necessary. You could leave it free-standing, or if you were a real stickler for details, go ahead and find the studs and mount your vanity to them using L brackets or metal strapping. We are true DIY'ers, this may not be what a paid contracter would do, but then we didn't pay anyone now did we!
Once your vanity is up, line up your downspout and crank it on. Don't overtighten.  Remember, silicone tape is your friend. Hook up the hot and cold lines and test out your job. Running water? Success!
Step 6: Add hardware to make plumbing accessible!
You don't want to nail this cover back on, like what you'd commonly find over the front of a kitchen sink. You may need to get in here in the future!  Purchase these cupboard door clips for a couple of bucks at your hardware store. They have a boy and a girl side; put the girl side on the vanity itself and the other half of the hardware goes on the drawer front. Now, snap into place and marvel at pure genius! Should you ever need to gain access to this plumbing, it's a snap.
ToniRose says: Apr 8, 2012. 7:55 PM
Great idea making the access point; those clips were an inspiration.
I'm glad you repurposed the blue toilet. My apartment has a seafoam green one, and I may steal it when I move.
Oldbear says: Aug 16, 2011. 10:53 AM
Sanding after the drilling would make for less touch up.
Oldbear says: Aug 16, 2011. 10:37 AM
You might be able to swing a cat it there - if it didn't mind a few nasty knocks about the head...
Great Instructable - we're renovating a house soon - and are already searching for a piece like this for our en-suite - that way if it sucks, only we see it - if it works we'll do the same in the basement bathroom.
sunshiine says: Jul 1, 2011. 2:12 AM
Oh! thank you so much for sharing this ible! Nice work!
kathynv says: Jun 28, 2011. 7:10 PM
Great job! Just this morning, on one of those, "No One Will Buy Your Crummy House Unless You Do This Our Way" programs on HGTV, they installed a two sink vanities that were similar to your project, except for the ridiculous price - $2,000 for the bottom, and another $800 for the sink bowls -- each! The ones on TV weren't floating like yours, although they showed how to put 2"x4" reinforcements in the wall before installing the cabinet part of the vanity. For the price they were quoting, it would be cheaper to buy a brand new chest and modify it to use as a vanity.
Thanks for sharing your project with us!
jessandstavro (author) says: Jun 30, 2011. 9:36 PM
It's hard not to feel kind of smug, when you see what they spend on those decorating shows! Our sink was $49, faucet around the same, $10 nightstand and three cans of spraypaint...pretty affordable!
flyingpuppy says: Jun 29, 2011. 4:57 PM
Thanks for these instructions! And that's a very good vantage point for admiring your handiwork. : )
skiedra says: Jun 28, 2011. 2:25 AM
A great idea made right! Keep up the good work, Stavro!
CaseyCase says: Jun 26, 2011. 11:28 AM
Nice instructable--I like the floating effect.
Do you have problems with your vessel sink draining? I have heard that since this style of sink has no overflow, it tends to drain poorly.
Fhq says: Jun 27, 2011. 10:57 AM
I have a similar sink, and I haven't noticed any issues with drainage.
jessandstavro (author) says: Jun 26, 2011. 6:46 PM
This one does have a shiny, chrome overflow, just not pictured. I've seen others though, that don't have the overflow. I think the fancier, clear glass ones you can get don't have it.
GeekTinker says: Jun 27, 2011. 12:26 PM
You can see the chrome overflow in the second picture.
Ward_Nox says: Jun 26, 2011. 8:31 PM
i'm planing on doing this exact thing in my house i just havent found a good dresser/table i like yet
chouf says: Jun 26, 2011. 12:39 PM
very nice job ! Good idea to use cupboard door clips
missplumeau says: Jun 26, 2011. 8:07 AM
Very nice instructable! I did a number like that years ago and didn't take pictures. I knew someone would post something similar on 'Ible. Cheap, easy and the result is so gratifying! Thanks for sharing your project.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
