This instructable will tell how to make a floor cleaning robot that uses Vex Robotics System as a base platform.
The robot uses a paint roller to pick up crumbs and dirt and moves them into a dustpan. Also, a water tank continuously drips water onto a mop that rotates back and forth. Dragging behind the bot is a towel that dries the floor and picks up any leftover dirt.
The robot also navigates it way around by following a line of tape, so you don't have to watch over it or control it.
This is an entry for the 13-18 age category in the robot contest.
Remove these ads by
Signing UpStep 1Parts Needed
For this robot you will need:
-Vex Micro-controller with battery pack
-Vex Line Sensor Kit
-4 Vex Motors
-1 Vex Servomotor
-2 short square axles
-2 12inch square axles
-2 black grommets
-2 rubber wheels
-Assortment of hardware
-several different vex beams
-tie-wraps
-bailing wire
-scraps of wood
-9 inch paint roller
-Dustpan with rubber edge
-12inch plastic plumbing pipe with 2 plugs that fit into either end (the pipe should be about 1.5 inches wide)
-towel
*Any of these parts can be replaced with others, but if any technical part is changed you may need to change the code.
The only disadvantages of this design are that you have to put a line on the floor, but I am working on a system to navigate using an ultrasonic sensor to measure the distance away from the walls. The other thing is that you have to manually control the water flow, but I hope to update this instructable by adding how to control the water with the microcontroller.
