3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Floor mount light
Step 5Attaching the bulb and plexiglass
***What you'll need for this step***
>Drill
>Screws
>Scissors
>Transparent plastic sheets
>Plexiglass piece from step 2
>Tinfoil
>Assembled bulb/wire/plug from step 3
>A4 paper
>Screws
---First you have to unattach the wire from the socket an
pass it through the hole left from step 1 and reassemble.
Cut the shape of the housing out in tinfoil, and put it under
the bulb.
---Then put hold the plexiglass in its exact position while you
drill through the small 'extrusions' and into the floor.
---Then use the A4 paper, transparent plastic sheet and cut the
shape of the plexiglass. Stick these identical shapes to the
underside of the plexiglass piece so they hang there
properly and dont fall off.
---Then turn the plexiglass/cloroured sheets over, match the
drilled holes and screw it on.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:daniel2008
