3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Floppy Disk Bag Retrofit: EL Wire
Since many of my classes this term will be at night and after seeing how cheap EL wire is, I decided to add some to my bag, since many of my classes this term will be at night. This will also increase visibility when using it as a bike bag.
What You Will Need:
EL Wire: To illuminate the edges of the standard matrix you will need 10' of 2.2mm wire
DC-AC Inverter: the EL wire I ordered came with an 3V (2AA battery) inverter but you can build
your own using the wonderfully written instructable How to Add EL Wire to a Coat or Other Garment
Screws: see the third step for more info.
Step 1Thread the EL Wire
Thread the EL Wire
The EL wire fits snugly under the knots around the outside corners, I went around the edges, to illuminate the general shape; However you can easily thread it however you want or create your own designs.
18 comments
Sep 21, 2008. 5:10 PMMaruaderFox says:
Which ebay seller do i buy the wire and inverter from???
Sep 3, 2008. 8:10 PMalex-sharetskiy says:
Awesome! how much was that inverter?
Sep 5, 2008. 3:27 PMalex-sharetskiy says:
what output voltage?
Sep 5, 2008. 9:57 PMalex-sharetskiy says:
you could have made this one.
Sep 4, 2008. 3:07 PM=SMART= says:
Where can i get relatively cheap EL wire ??
Sep 5, 2008. 8:36 AM=SMART= says:
awesome i can think of loads of cool projects to do !
Sep 4, 2008. 3:15 AMfegundez1 says:
where did you get the wire?
Sep 3, 2008. 7:29 PMnoahh says:
I wish this had come out earlier. I JUST finished my bag last weekend after a week of hard work.
Sep 4, 2008. 8:17 AMjongscx says:
that's the beauty of it... the EL wire just slips between the strings... it's a "RetroFit"...
Sep 4, 2008. 8:34 AMFreshPineSent says:
The whole goddam thing is a retrofit!
Sep 4, 2008. 9:29 AMjongscx says:
not exactly. You're not Retrofitting the disks into a bag. You're Repurposing them because you are creating a new purpose for the items. You are However, Retrofitting the EL wire into the disk-bag because you're fitting a component into a pre-existing object.
Sep 3, 2008. 11:14 PMthermoelectric says:
That looks so cool
Sep 3, 2008. 11:07 PMaliceownsj00 says:
That is so cute haha in that geeky way. I'd so use it on a daily basis!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
44
Author:imanalchemist
