Check out the update (2008) and my new bag: Floppy Disk Bag: Install Disk 2
Remove these ads by
Signing UpStep 1Required Bits
1/8" drill bit
Pliers, I used bulldog pliers
Floppy disks (CRUCIAL)
Links, bits of chain from your local bead store
Nails and a plank o' wood
A pen
Elementary math skills Eg: the ability to count
NOT PICTURED
The hardware for adding a strap
the strap
I have ca. 50 new floppy disks I don't know how to get rid of. I can send them to you for free if you can cover the postage and if you are still interested of course.
^there
Very creative way to reuse useless floppy disks! i'll be keeping my eye out for floppy disks the next time i go out now, they definitely make better bags than coasters!
They usually sell in paks of 5 or 10 for a little more than what one jump ring seems to cost. If true stainless steel is not available, some fishing ones are labeled as "English stainless" which is actually some kind of plating on either steel or brass, but seems to resist corrosion fairly well. It seems like these would be easy to install as compared to having to bend open and then bend closed the split rings, as long as you buy relatively thin split rings. If opening the split rings is difficult for you (as for me, having lost some feeling in my finger tips as I get old and decrepit), you will find very near the split rings in the sporting goods store a tool called a "split ring pliers" (for about $10). The pliers make opening them simple.
Here's a couple:
copper
http://www.gossamerwingsdesigns.com/Jump-Rings-Chain-Maille-7-copper-jump-ring.htm
stainless steel
http://www.firemountaingems.com/details.asp?PN=H209247FD
http://www.instructables.com/id/Paperclip_Jump_Rings_No_way/
Thanks,
http://www.streamline-markets.com/
Thanks,
http://www.streamline-alliance.com/
Thanks,
http://www.stream-max.com/
I am really impressed with your blog. I started blogging in 2007, after a job lay off. My goal was to immerse myself with social media both for personal and professional interests.
Thanks,
Mark Smith(http://www.healthinsuranceinfo.org/)
