3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Floppy Disk IR Camera Hack
For the past seven years, I've had a broken digital camera lying around. It is still able to take pictures, but it is almost impossible to use on account of a broken screen. The fundamental problem is that sometimes the menu will accidentally get turned on, and not being able to see the screen, I can't turn off the menu and take pictures (without removing the batteries to reset the camera). I've been trying to figure out what to do with this camera as long as I can remember.
For a while I was considering converting it to a near IR camera, but I was reluctant to make another one after having already made one for 62 Projects to Make with a Dead Computer (p. 200). However, I changed my mind about this when I learned that it was possible to use the material inside floppy disks as a visible light filter (for viewing near IR light). This sounded really cool and so I decided to give this a try. Not only does this totally work, it also adds another level of computer reuse to the version demonstrated in the book (as it provides a way to reuse floppy disks in addition to cameras).
It has been fun going around shooting pictures and discovering all of the interesting results when I upload the photos at home.
Step 1Go get stuff
Go get stuff
You will need:
A (somewhat) broken (or antiquated) camera
A floppy disk
A mini screwdriver set
Pins
Scissors
Glue
90 comments
1-40 of 90next »
Dec 7, 2010. 10:37 AMhivoltage says:
I picked up a samsung 10mp point and shoot camera with a slightly broken lens mechanism on ebay for a steal then repaired it and did this floppy disc modification to it. results have been great! photos are very surreal and it is fascinating to see a things all around that your eyes cannot see. Finally those old AOL floppy discs have come in handy lol
Dec 12, 2010. 10:20 AMhivoltage says:
Thanks! I was surprised how much of its focusing ability the camera retained after I modified it, I guess because the IR cut filter on this model is very thin, only a tiny bit thicker than the floppy disc section that replaced it. I did tweak the contrast, levels and saturation a bit in these photos, but other than that they are pretty much unmodified. The first two I took above at Cal Poly Pomona are probably my favorites. The camera is a Samsung SL202 and it was very easy to disassemble and modify. Tried to do it to another point and shoot I had lying around first but it seems that the IR cut filter was coated right onto one of the lenses instead of on top of the CCD like this one and yours.
May 5, 2012. 6:34 PMthebodycopy says:
This is, I think, exactly what I was looking for. I have an old Sony Cybershot F717 from 2003. However, the CCD chip is bad, I believe. (It used to take glitchy pictures, but now it's just black...except for the menu.) I am a video artist and am interested in hacking it for creative purposes....with the CCD chip dead, will this hack you posted still produce an image? I'm new at hacking this stuff, so please forgive any silly questions.Thank you SO much. Any advice is appreciated.
Dec 13, 2010. 3:21 PMterrapinlogo says:
These are some pics i took with the floppy disc taped over the lens without taking the camera apart. the first two where taken with a 10mp Panasonic Lumix and the second two where taken with my HTC touch 2 smart phone
Mar 22, 2012. 11:42 AMafardella says:
... but in this way you don't allow IR to get the CCD sensor..... you are using the floppy like a whatever filter.....
Jul 14, 2011. 3:23 PMaenke says:
So I've seen a few comments on people getting shocked when they open up the camera. Is there a way to avoid that?
Mar 22, 2012. 11:37 AMafardella says:
Hi,
i think that the best is not to get scared of the technology :)
Greetings
Nov 29, 2011. 7:52 PMilpug says:
Yes. In cameras there is usually a large capacitor. This thing is usually charged, so when you see it, discharge it by putting the tip of an INSULATED screwdriver between the contacts. do this two or three times, and it will be safe. By common practice, also make sure that all batteries are out of the camera before you dissassemble it.
Feb 7, 2012. 9:16 AMPoggibonsi says:
I made this hack to my old 2mpx camera but photos are blurry. I don't know if now it can't focus well or if the problem it's the 2mpx. (can't remember the quality of the photos...) Someone can give me an advice?
Thanks
Jan 6, 2012. 1:39 PMdan616 says:
could i do this with a disposable camera?
Nov 29, 2011. 7:46 PMilpug says:
I am going to do this for my senior project with an old Canon Powershot camera I have.
Oct 16, 2011. 3:32 PMcompaqxp123 says:
It just occurred to me, but when using IR Film you need to adjust the lens focus.
So on an older fixed focus point and shoot digital the photos will be blurry at first. You need to find someway to adjust the focus on them because it will need to be changed ever so slightly.
It's easy to do this on many cheap point and shoots.
Oct 16, 2011. 5:33 AMcompaqxp123 says:
I wasn't sure about this until today, when I bought a Kodak Easyshare cx6200 for 50C. I saw it on the shelf and knew what I had to do with it.
Mind you I've already found it's limitations (it's very bad at infinity/anything past a certain distance) and the 2mp is just a bit lower then I'm used to dealing with.
Either way I've taken a few photos. I didn't like the brownish tint so I tried to edit them, not knowing how they should really look.
http://img62.imageshack.us/img62/4236/1008617s.jpg
http://img844.imageshack.us/img844/5452/68780899.jpg
I'll just assume it's so blurry because of the camera itself.
Jul 15, 2011. 10:12 AMchubby8 says:
will this work in the dark? possibly with the help of some IR LEDs
Jun 9, 2011. 8:38 PMaidanjarosgrilli says:
If you know what the vivid festival in sydney is, you could tahe a photo of the opra house or the projectors.
Jun 4, 2011. 8:18 PMforwardbias says:
I just made modded another camera, 10MP, Vivitar Vivicam X018. Cheap camera without optical focus. Picked it up for $45 from Walmart Site to Store. Pictures are grainy/noisy in low light compared to more expensive cameras, but you get what you pay for. Outside with plenty of light, pictures are quite good, and with the IR hack, its a cheap way to get high res IR images. These are shots I got from Mt Lebanon Cemetery in Lebanon PA, as well as Stovers Dam.
The images normally have a reddish color to them, but in the camera settings I set the camera to capture in mono chrome. To give the effect of using a SLR camera with black and white IR film.
May 22, 2011. 11:22 PMforwardbias says:
I just did this on a Philips point and shoot, however the IR filter was inbedded into the same housing as the lens was. I was able to carefully break the thin glass of the filter and remove it, then cleaned the tiny fragments inside. Rather then put the floppy disk material over the CCD though, as the original filter was not there, and trying to insert it into the housing and getting it perfectly straight would be a problem.
I sandwiched the disk material between 2 squares of plastic that I cut from a jewelcase, and then made it so the only light that could get into the camera was through the disk material. I then glued my IR pass filter directly to the outside lens of the camera. Looks alittle crude, but it seems to work on the things I tested so far. It was pretty late and cloudy on top of that.
However, on lamps with incandescent light bulbs, with the camera, it appears very bright, however, putting the same disk material over a non hacked camera that still has its IR filter, you cant see anything.
Fluorescent lights though, its very dark, can barely make out the tubes on the view finder. Shows how much energy light bulbs waste, giving off most of their energy in IR. The light from Laser mice is very visible.
I then passed 5,000 volts through 2 flash tubes, which is visible with my regular camera, but is much, much brighter on my IR hacked camera.
I also tested a stove, turned the burner on high, on IR, it appears bright white, and glows before I can see the red glow or before my non hacked camera can see it.
I then did a shot with the flash on aiming at a mirror, as well as a picture of me with flash in the dark.
Hopefully the weather is clear so I can test the camera out in the sun tomorrow.
Sep 2, 2010. 1:09 PMPSPerson says:
kirkland brand batteries... ahh, i love costco.
May 15, 2011. 5:01 PMilpug says:
Costco FTW!
Mar 21, 2011. 1:01 AMJuCo says:
good to know that i can use that stuff... i've still got some spent film for these ir filters, but that disc would give more material in one piece than a 35mm strip does.
and to hivoltage: well, now i know someone here lives in my area... i recognised that sundial-looking building instantly. i had a friend who was a chem professor at cal poly. as a sidenote, keep ahold of that picture. i read somewhere that they're tearing that complex down. (the "sundial" and the building next to it)
Mar 14, 2011. 11:32 PMk.ghia says:
Great hack. Now i just wish i had saved some floppy disks. Oh well, off i go to see if Fry's still stock these things.
Mar 2, 2011. 6:13 PMcybergod says:
Now this looks like a somewhat simple project for a movice like me. I have an old Sony Mavica laying around, some old floppies (the Mavica stores stuff on the floppies) so pretyt much everything needed . . .
Might need to try this on the weekend :-)
Thanks
Feb 26, 2011. 10:21 PM101yummYYummy101 says:
Whenever I try to look through the floppy disk, I just see dark red with a spec of light from the sun and other really strong lights. I cant really see much. And yeah, Ive taken apart a disposable camera before and was too lazy to discharge the capacitor first, and after getting shocked 3 times it was pretty much discharged by me anyway lol...
Nov 29, 2010. 1:06 PMWalis says:
Guys!!!! This is the most awesome instructable for cold winter evenings (like we say here in Czech Republic). You can easily check the functionality with your TV remote!!! Also good for tracking the surveillance cameras in the street. COOOL!!! LET THERE BE LIGHT!!!
Jan 12, 2011. 9:23 PMsillywilly says:
Thanks a bunch Walis! I tried that test on my phone's camera and what do ya know! Two dots of light appeared. Covered the camera lense with the floppy disk and viewed it live through my phone camera. Only by viewing this through camera did the IR light from my remote show up. This is fun. Like someone else said, I think I'm becoming a "ible" junkie! 8--]
Dec 6, 2010. 5:26 PMccrh2008 says:
This is a good idea. I saw a show on Discovery Channel about futuristic technology or something, at one point they were talking about X-ray cameras and how some cameras are already equipped to do this. The process they were talking about involved enabling a camera to see only infrared light, and since infrared light passes through most objects, it works in a way that could be described as X ray vision. So I took the IR light filter off of my camera and was thinking of what I could use for a V light filter. And now I have a V light filter. Muahahaha... Thanks This is an awesome idea.
Dec 12, 2010. 6:58 AMMarinus84 says:
You don't really think IR light passes through things right?
"Another interesting fact about infrared light is that it can travel through thick smoke, dust or fog, and even some materials."
Thats about it, so it's not possible to use it like an X-ray camera :) That would involve radiation ofcourse :)
Dec 12, 2010. 10:09 PMbaratacus says:
I.R. is radiation, All light is radiated, the visible you can detect with your naked eye, the invisible on either end of the spectrum you can't see. I.R. and U.V. I.R. is radiated by heat sources. Your body generates heat and therefor produces I.R. radiation. I.R. can be filtered and reflected like visible light. It has a longer wave length (shorter frequency) than visible light and can penetrate objects that would absorb visible light.. Microwave radiation is even longer wave and can pass through objects that IR can not, Radio waves are even longer wave radiation and can penetrate objects that microwaves can not get through. The longer the wave length, the higher the penetration. If you can filter (convert) that frequency of light to a visible (shorter) wavelength using an optical fliter, then you can see what that frequency of radiation is reflecting off of or being emitted from. We used to play laser tag as a kid in the park at night. A friend of mine had a pair of night vision goggles (chinese military surplus) and he could see heat signatures from the other players, and when we'd fire our guns, he could see the I.R. beams like they were flashlights.
Some airports are using IR boosted imaging scanners to show a thermal differentiation between the body and the clothing worn To filter out more of the visible light, you can stack the filters so that your visual representation of the I.R. spectrum is more pure.
Dec 13, 2010. 7:19 PMVengence says:
The modern and widespread use of the word radiation refers specifically to ionizing radiation, which does not include IR.
Jan 9, 2011. 3:51 AMmikiex says:
Just because a word as been adopted in this way to refer to a specific "Bad" radiation doesnt mean it cannot be used to describe the process that is radiation of which there is no better word to describe it and is the correct current scientific term! :)
Jan 9, 2011. 7:54 PMVengence says:
Wrong. That would be like using the word gay to mean happy. It just isn't done that way anymore. What a word has been adopted to mean is completely relevant.
There's no better way to describe it? The better way to describe it is to be specific as to non-ionizing radiation...
Jan 10, 2011. 2:50 PMmikiex says:
This is not true at all, if someone says Infrared radiation it implies you are talking about non-iornizing radiation. You don't need to say it is non-iornizing because it is a known fact that it fits into this band of radiation.
You are saying the word radiation cannot be used with non-iionizing types of radiation because the layman term radiation now only means ionizing radiation.
Where as the scientific meaning has been unaltered.
I better go and turn my non-ionizing radiators down as it's hot in here....
Jan 10, 2011. 8:24 PMVengence says:
You ARE specifying non-ionizing by saying infrared. You didn't just use the word "radiation" standalone. You're not disproving the point...
Dec 13, 2010. 2:20 AMkeithisit says:
Airport scanners use light from the far end of the IR band, they are very good at seeing through clothing, plastic and paper but cannot penetrate body mass because water is very strongly absorbing at this wavelength.
Dec 13, 2010. 6:35 PMVengence says:
Are you guys talking about the backscatter scanners? No, those use actual x-ray radiation at "low" output(still unhealthy), not IR light...
May 26, 2011. 7:37 PMkeithisit says:
Nope, what I'm talking about are scanners working in the far-IR (if your an engineer) or THz (for you physicists) region.
They are used quite widely throughout the packaging industry as well due to the high transparency, at THz freqs, of most packaging materials and the very low energy of the beams.
Jan 3, 2011. 3:08 PMItsTheHobbs says:
I will definitely do this with an old camera that I have lying around. Also, you can make them look better by removing the red in Photoshop/GIMP, like this.
Jan 8, 2011. 8:41 PMInducktion says:
It looks like a post apocalyptic world. D:
1-40 of 90next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
42
Author:62 Projects to Make with a Dead Computer(The Official Book Site!)
Computer hacking takes on a whole new meaning when you're going at it with a hacksaw and screwdriver: announcing the most wildly inventive, eco-friendly craft book on re-purposing everyday objects sin...
more »
