3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Floppy Disk Notepad
Step 2Make a Template
Make a Template
Unless you have floppy-disk-sized sheets of paper readily available, you'll need to cut your own sheets of paper. Now, this is not as tedious as it sounds, so you can stop freaking out about cutting out 30 sheets of paper one at a time.
First, we need a template. Lay the floppy disk on one sheet of paper and trace around it. Draw a couple of lines inside the template on the left and right sides, about .5cm in. Do the same for the bottom, too, then cut it out. This is so the paper is just a little smaller than the floppy disk, you don't have to do this unless you don't want the paper coming out the sides.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
265
Author:1up(ModRetro)
Sometimes my Instructables are few and far between, but I try to make them as well as I can. Hopefully you can be inspired or helped by the content in them!
