Step 4Almost there
iImage Information
Now that you have taken the floppy apart it is time to put it back together. First though you can glue the black disk thing to the inside of the floppy on the side that the hole in the hard plastic cover is. You do not have to do this, i did not, but if you would like it to be a bit more secure you can. After you do this you have to screw the halves back together (with the black disk still inside). As you can see in the picture you have three or four (mine had four) on the bottom and one on each side halfway up. Sorry but the picture in this is upside down. It is easier to screw them through if you drill a small hole first but you may be able to do it without doing this.
