Flower Bracelet
5,393
46
Posted in CraftJewelry
Introduction: Flower Bracelet
Fun, easy to make!!
Step 1: Things You Will Need
      Beads, bead weaving thread (clear recommended), Beading needle (optional),brooch
Step 2: 1st Step
Measure your hand with the beading thread and cut about six to seven times bigger than your wrist. The amount of the thread may seem long, but once you start inserting the beads, the thread will get shorter.  Insert the brooch through the thread and leave about 2 inches and secure it by a double knot. When you have done that insert needle leaving the part where the brooch is tied longer than the other side.
Step 3: 2nd Step
Choose seven beads of the color you want.  Insert beads through the beading thread.
Step 4: 3rd Step
Tighten around your finger, insert the needle into four beads.
Step 5: 4th Step
Pull the needle. When you pull the needle it will form a circle. Then insert another bead of another color you want.
Step 6: 5th Step
With your nail try to put the bead that is outside the circle in the center of the circle.
Step 7: 6th Step
While holding the bead in the center, insert the needle in four beads
Step 8: 7th Step
Pull the needle while holding the bead in the center and it will form a flower, pull to tighten it and to move it close to the brooch, continue this until you have made the size you want.
Step 9: 8th Step
When you have done the last flower, insert the other half of the brooch and secure it by making double knot. When you have done that cut the remaining thread on both sides. To ensure that the thread does not fray, you can burn the ends carefully.
    • Trash to Treasure
      Trash to Treasure
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    Omigosh,my grandmother got a necklace with these flowers at trade day,and it's been bugging me,like,'What are those made of!?' So in other words....THANK YOU SO FREAKING MUCH!!
