Step 2Pattern Making
Using the computer and programs like AutoCAD and Adobe Illustrator, I was able to trace, rotate, scale and combine the gaskets into a pattern that I found appealing. In this pattern you can see that the different lines have different weights or thickness; this determines what intensity the laser cutter will cut. The lighter the line, the less intensity of the laser. In this case the light lines were only scored, while the heavy lines were fully cut through.
Add Comment
