Flower Magnets
337
4
Published
Introduction: Flower Magnets
Want to learn how to make flower magnets? You can learn here! Have fun!
Step 1: Gather All the of the Supplies
You need: baking cups, one piece of green paper or you can color a piece of paper green, scissors, wet glue, a magnet you can cut ( you can get one from the back of a magnet list pad, get an worn out magnet, or any other magnet you're not using. The magnet only needs to be around 1 inch long and you can always cut magents.)
Step 2: Make the First Layer
Step 1: Get out a baking cup Step 2: flatten it down Step 3: pop it back up= your first layer of petals!
Step 3: Attach the Magnet
On the first layer, attach the magnet on the back. First, flip over baking cup to the back. Next, cut out a piece smaller than your baking cup (the first layer). Then, put glue on the back of the magnet. Next, put it on the back of baking cup. Finally, let it dry for 5-10 min.
Step 4: Make the Second Layer of Petals.
First put some glue in your first layer baking cup. Next , with the point of the wet glue bottle, spread the glue all around. Finally, put the second layer baking cup inside the first layer. Let it dry for 5-10 minutes.
Step 5: Make the Third Layer of Petals.
Get out another baking cup. Fold it so there is six points. Or you can fold it a different way. It just need to be smaller than the other baking cups. Then, put glue inside the second layer. Spread the glue around the second layer. Next, put the third layer inside of the second layer. Let it dry for 5-10 minutes.
Step 6: Make the Bract/leaf
A bract is a leaf that is close by the flower. First, draw a leaf. Next, cut the leaf out. Then, put some glue on the back of the leaf on the end and put it on by the magnet, put not on it. Do this again for the second leaf. Put the second leaf across from the first leaf. After dry for 5-10 minutes you're done!
Step 7: Good Job!
Good job! You've just learned how to make a flower magnet!
    • BBQ Showdown Challenge
    • Stick It! Contest
      Stick It! Contest
    • Backpack Challenge
      Backpack Challenge
    2 Discussions
    This is cool. Bet it would look awesome with different colors. Maybe do another Instructuable with different color baking cups and enter in the the paper craft contest going on right now?
    If you have any ideas of what I should make next you can tell me!
