Flower Pot Address Markers
378
21
Posted in HomeGardening
Introduction: Flower Pot Address Markers
Using some pots to mark you house address can be a nice touch to your home.
You can color each pot a different color or have them uniform like the pots in the picture.
You can use any size or shape of pot as well
Step 1: Gather Your Supplies
Gather your supplies
  1. Paint brushes
  2. Small plastic cups to hold paint
  3. Brushes
  4. Acrylic paint
  5. All purpose sealer
  6. Exterior varnish
  7. One terra cotta pot for each house number
  8. removable vinyl or vinyl numbers
Step 2: Prime Your Pots
Terra cotta pots are very porous and absorb moister easily. If you do not prime them they will not hold the paint well.
be sure and prime all surfaces of the pot, inside and out
Step 3: Cut the Numbers Out
You can purchase removable numbers or cut them out by hand or with a vinyl cutter.
The size of your numbers will depend on the size of your pot. A larger pot will need larger numbers.
It does not matter what it looks like as it is only temporary and will be removed. I use a really obvious patterned shelf paper as it is cheap
Step 4: Apply the Numbers
Peal the back off the numbers and apply them where you want them
Be sure to adhere them well to the pot so the paint does not seep behind them
Step 5: Paint the Pots
Paint the pots on the outside all the way around and the rim inside and out
Usually, you leave a gap between the top of the dirt and the inside of the rim, so it is nice to have the rim be the same color as the rest of the painted pot
let dry completely and add a second coat if you are using craft paint. if you are using house paint, you may be able to get away with only one coat
Step 6: Remove the Vinyl
Remove the vinyl once the paint is dry
You may get a little seepage
You can fix it by simply scraping the pot with a craft knife
Step 7: Finish the Project
Cover the entire pot, inside and out with the exterior varnish. The varnish I use requires four coats to seal well, so be sure to read the instructions on your varnish container
Anyplace you miss with varnish will allow water to be sucked into the pot and will cause your paint to bubble.
Enjoy your pots with freshly planted flowers!
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    A really bright and good looking idea for any home, Including mail box's etc.
