3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Flower Pot Smoker (Improved Lid)
There are already quite a few instructables out there for Alton Brown's Little Brown Egg smoker, but I thought I would share my improvement to the lid design.
One of the hardest parts of this smoker is finding the suggested pottery piece for the lid.  I ended up using the drain pan for the pot size that I picked.  I also didn't like the idea of using a Teflon pan sitting on the burner (something about carcinogens being released at temperatures as low as 464°F), so I opted for an 8" cast iron skillet.  I hated to destroy an otherwise perfectly good cast iron pan, but it was worth the sacrifice for a quality wood chunk vessel.
Step 1Materials
Materials
Materials Needed:
1    Flower Pot
1    Flower Pot Drain Pan
1    Single Burner
1    Grill Grate
3    Flower Pot Feet
1    Fence Gate Handle
2    Screws Long Enough to hold it the handle through the lid
2    Nuts for the screws
4    Large Washers
1    Grill Thermometer
1    Masonry Drill Bit (of appropriate diameter)
1    Sheet Automotive Gasket Material (Not Shown)
1    8" Cast Iron Skillet
34 comments
Jun 6, 2011. 7:04 PMschmiez says:
Anyone have suggestions for mounting / regulating the thermostat so that it cycles properly? The first few times I rigged up a foil structure afixed to the bottom pot so that it cycled. took a few hours to fine tune it so it wouldnt get too hot.
I cant imagine it would take much. maybe just an electrical box attached to the bottom pot? Any other thoughts? the littlebrownegg.com hack doesnt address the fact that he thermostat has to cycle and as they have it, it wont cycle, just continuously heat.
Jun 7, 2011. 5:39 AMschmiez says:
Ahh, gotcha. Mine is an old school thermostat. Just searching for some answers on a quick, easy, and cheap fix to better control the temp.
Got extremely lucky the first two times i used it as it was hot and calm outside, so a foil housing did the trick. But I'd like something more permanent.
May 5, 2011. 8:06 PMlinuxuser00 says:
Well i really like this build, being from Texas I BBQ with my family alot but we rarely ever smoke anything so I want to give this a try at the next BBQ competition even if its just to sit out and make something for us to eat for ourselves at the end of the day. I am pretty good at modding things but I need a little bit of guidance. What size flower pots did you buy I just need the size of the one on the bottom I can just go and look for a drain after that. Also what size grill did you end up using. I plan on rewiring the control into a project box about a foot or more down the power cord for easy adjustments. I can make an instructable on the wiring I suppose if anyone is interested.
Dec 10, 2010. 1:27 PMjshank says:
Anyone looking to build your own flower pot smoker or discuss design and mods is welcome to join littlebrownegg.com. It's a community of people who love the DIY smokers.
Jun 4, 2010. 11:05 PMlovindutchovens says:
Instead of ruining a good cast iron skillet look for a cast iron pie plate. Camp Chef has one.
Mar 22, 2010. 5:25 PMgnawlej says:
I'm happy to see someone else drilled the floor of their smoker to run the hot plate wiring on the outside. This really makes breaking it down to move, store or clean a lot easier. However, I left the burner housing (I have the same model you used) intact and set the bottom pot directly on top.
To drill the terra cotta, I just turned my garden hose on to a trickle and set it on the surface while the masonry bit did it's job.
Apr 10, 2010. 1:15 AMgnawlej says:
Mar 24, 2010. 10:44 AMgnawlej says:
I see. Since I left the hot plate housing intact, routing everything through the drainage hole put stress on the wires. If the coil teetered when dumping ash and adding chunks, the contacts could come undone. Needless to say, reconnecting these in the middle of a 12-hour smoke was not fun. Now I understand your steel tubing standoffs (I had thought those were acting as a conduit, routing the wiring through the floor), which seem to achieve the same goal as my drilling through the floor, keeping the coil level and stable. I've also noticed the wires take a bit of a beating, even with the thermal insulation, when they are routed inside the smoker.
I'm planning to smoke a brisket Saturday, so I will take and post some pictures then.
Mar 6, 2010. 10:43 PMspylock says:
Where did you get your replacement grill grate if I may ask,that is the only thing Im lacking at this point,my hotplate isnt the coil type its flat,and looks as though it were made for what im doing,it has one bolt to where the burner can be raised off of the base about an inch or so,it was $18.00 which I thought was kinda high for a single burner hotplate,but what the hey it should work well.
Mar 7, 2010. 12:32 PMspylock says:
Great,thank you,yea my hotplate came from walmart,I wouldve got the coil type had they had it,but Im really making it for my brother as a birthday gift so I wont complain too much,and like I said it looks as though it were made with this project in mind,we shall see,and I will post some photos when finished,but Ill have to get my brother to show me how to do that,Im pretty O.K. with my hands but my computer skills are lacking to say the least..Thanks again for the info.
Mar 18, 2010. 3:39 PMspylock says:
That hotplate I got woudnt work with having to cut and extend wires,a whole lot of extra work,so I did like you and got the cheaper one,which is what I should have done to began with.
Mar 18, 2010. 9:03 PMspylock says:
Yea,but I took it apart,Ill put it back together and use it in hot water blueing smaller gun parts,I needed another for that as far as apperance goes.
  I was going to ask,how important do you think the temp.guage is,and if its a have to,can I get that a lowes or home depot?
Mar 19, 2010. 9:31 AMspylock says:
Hot water blueing requires equipment and cemicals that are fairly expensive  ,to do things like gun barrels and receivers anyways,to tell you the truth nowdays there are cold blue solutions that do just as good of a job if instructions are followed,but certianly if I get one to do,Ill get my brother to help me download an Instuctable on it.Thanks for the info on the temp gau.,I guess Ill get this smoker done one of these days.
Jan 24, 2010. 5:57 AMkill-a-watt says:
looks yummy!
If I could make a plea, please don't cut the handle off a vintage cast iron skillet, at least not until the Chinese learn how to machine the insides smooth.
Import cast iron is all over the place and you can tell by the fact that it's got a rough, as cast, finish in the cooking area. Heck even recent domestic pans skip that step nowadays.
I can tell from your photo (besides the fact that you said it was new), that the inside surface has not been machined. I'd hate to see a classic Griswold destroyed, even if it was for the purpose of creating 'q
Mar 6, 2010. 10:52 PMspylock says:
Youre right about the cast iron coming out of china,I have very old pans and dutch ovens that have been in my family since well before I was thought of,and Im forty something,I wouldnt take anything for mine,once seasoned ,they very rarly have anything stick and dont you just love the way they hold heat..
Jan 24, 2010. 12:19 PMkill-a-watt says:
not an argument.
I'm asking other people to not ruin quality cast iron.
I've got a few Wagner's 1891 Original cast iron pieces myself, and they're unfortunately nearly useless for cooking anything except deep-fried because of a lack of a smooth cooking surface
I got 'em cheap at a a yard sale. The former owner looks like she tried them once or twice, and then gave up. If I don't use them for casting lead or pot metal, they may be smoothed via power tools (though I'm afraid that's going to be a crap load of work) and pressed into service.
Mar 6, 2010. 11:22 PMspylock says:
You can reface them,it is a little bit of work,or if its not pitted too bad you can clean it ,season it and use it for frying foods that produce their own grease,such as pork,even beef as long as its got a good amount of fat.It may take a year or so depending on how often its used but it will fill in,you just have to be careful in how you clean it,useing and caring for cast iron cookware is an almost lost art form.Im also glad to know there is at least one other who knows and appreciates fine cast iron cookware.
Mar 7, 2010. 7:27 AMkill-a-watt says:
Oh, you said "reface them". Do you have any hints for what power tools to use?
I was going to start with a random orbital sander.
Mar 7, 2010. 12:08 PMspylock says:
That would be the way to go,if pitted really bad you could use a handheld grinder to remove the pits and then go with your sander with a course grain and step down to a finner grain to finish up,then as you know seasoning it is an important step,but you sound like you have seasoned one or two in your life.If not pitted bad than you could use your sander with course down to finer paper and it will turn out well.
Mar 7, 2010. 7:15 AMkill-a-watt says:
There is a world of difference between my antique cast iron dutch oven (which is finely finished on the bottom and sides, and then I seasoned it well) and this newly produced cast iron made here and abroad.
As I said, the newer pieces work great for deep-frying, but you will never, no matter how well seasoned it is, get an over-easy egg to cook right in that pan.
Mar 7, 2010. 12:15 PMspylock says:
Totally agree the new mass produced stuff leaves a whole lot to be desired,the iron itself isnt nearly the quality of the older,say before the turn of the century iron,and its not just with cast iron cookware,its woodstoves,railings, furniture you name it.
Feb 1, 2010. 8:55 PMSassy Cat says:
Thank you for the added pictures.
Jan 31, 2010. 9:07 PMSassy Cat says:
This really looks like fun, I want to try one.  I have one question though (and yes, I;m blonde), but where and how does the burner go in?  I don't see any pictures or instructions for it.
Jan 24, 2010. 11:31 AMTheCheese9921 says:
when I saw the tittle "Flower Pot Smoker" I though it was for used for something completely different than smoking food. hahaha
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:joshgoes
