Flower Origami Ball
504,517
635
46
Published
Introduction: Flower Origami Ball
I'm going to show you how to make origami ball, made from blossoms.
Step 1: Materials
You need:
  • post-it notes
  • double sided tape or glue
  • scissors (for the tape)
  • and some time :D
Step 2: Folding
Take one post-it note and fold it in half to make a triangle (picture 1). Fold the dash line to make a diamond (picture 2). Return the left part in the previous position (picture 3). Fold the right part in half (picture 4). Make the same with the left part (picture 5). Then fold the whole model in half (picture 6). Fold in half again like in picture 7, but this time put the smaller triangle under the bigger (see picture 8 for the result). Fold in the dash line and again put the smaller triangle inside (picture 9). The model is ready.
Now make another 4 leaves in the same way.
Step 3: Connect the Leaves
Now let's connect the leaves from the previous step to make a blossom.
Cut a piece from the double-sided tape and place it like is shown in the picture below. Then stick another model. The second picture is more detailed....Connect the other pieces the same way.
Press the corners a little for more realistic effect (pictures 3 & 4).
Make another 11 blossoms like this one.
Step 4: Connect the Blossoms
Take 3 blossoms and stick them together. See the pictures below. Continue to add blossoms until they become 6. Now you should have haft of the ball ready. The same way make the other half.
Step 5: Ready
The flower origami ball is ready!
2 People Made This Project!
  • Make it Move Contest
  • Spotless Contest
    Spotless Contest
46 Comments
If only this could be made into a light... O.o
Maybe a few LEDs at the center of the ball? Hmm
I made a holes in the petals and put Christmas lights in them. Looks quite nice... Thanks for the instructable !
How about an instructable on how you put the lights in them.. Also these will make photography props :) thanks for sharing!
It's beautiful :) Thanks for sharing this photo:)
can I add one more petal to each flower to make it hexagonal?
Of course, but i guess it will become bigger and maybe harder to glue the flowers together. It's up to you to try something different.
Hi! I am trying to make this origami flower and the 2nd part to the directions is not showing up. I was wondering if there is any way to have someone fix it.
No problem.....Problem no one's following me. :-(
Really nice. I wonder i I could spray paint them to make an ornament?
I made a TON for my wedding, and used black spray paint. They turned out really pretty. Here's a pic to show you my finished product!
(Some people were asking about double sided tape? I tried it, and didn't have much luck. I ended up using small amounts of Elmer's Glue to stick it all together, and I had really good luck with it. :) )
You should try :)
hi i really loved this so i made one. However my question is when i glued them all together to form a ball i had a hard time gluing them together since one by one the petal would come off. I used double sided tapes by the way any tip on how i can stick them all together perfectly?
i used a hot glue gun because i didn't want to risk all of my hard work to fall apart... it stayed perfectly for me and when i was finished i put a large rhinestone in the middle of each flower!
I have a suggestion about your concern Kim020289 based from experience.
Put double-sided tape to both surfaces you re going to stick together. You can have good reinforcement when you joined 2 adhesives together :-D
I hope this will help
<3
