loading
Picture of Flower origami ball
I'm going to show you how to make origami ball, made from blossoms.
Step 1: Materials
Picture of Materials
You need:
  • post-it notes
  • double sided tape or glue
  • scissors (for the tape)
  • and some time :D
Step 2: Folding
Take one post-it note and fold it in half to make a triangle (picture 1). Fold the dash line to make a diamond (picture 2). Return the left part in the previous position (picture 3). Fold the right part in half (picture 4). Make the same with the left part (picture 5). Then fold the whole model in half (picture 6). Fold in half again like in picture 7, but this time put the smaller triangle under the bigger (see picture 8 for the result). Fold in the dash line and again put the smaller triangle inside (picture 9). The model is ready.
Now make another 4 leaves in the same way.
Step 3: Connect the leaves
Picture of Connect the leaves
Now let's connect the leaves from the previous step to make a blossom.
Cut a piece from the double-sided tape and place it like is shown in the picture below. Then stick another model. The second picture is more detailed....Connect the other pieces the same way.
Press the corners a little for more realistic effect (pictures 3 & 4).
Make another 11 blossoms like this one.
Step 4: Connect the blossoms
Take 3 blossoms and stick them together. See the pictures below. Continue to add blossoms until they become 6. Now you should have haft of the ball ready. The same way make the other half.
Step 5: Ready
Picture of Ready
The flower origami ball is ready!
1-40 of 42Next »
Hi! I am trying to make this origami flower and the 2nd part to the directions is not showing up. I was wondering if there is any way to have someone fix it.
adale1232 years ago
Wow! Nice work!
slu6alka (author)  adale1232 years ago
Thank you!
No problem.....Problem no one's following me. :-(
Lorikills3 years ago
I love mine =)
If only this could be made into a light... O.o
Maybe a few LEDs at the center of the ball? Hmm
slu6alka (author)  AdamVigneaux4 years ago
Sounds good...
sbhide slu6alka3 years ago
I made a holes in the petals and put Christmas lights in them. Looks quite nice... Thanks for the instructable !
How about an instructable on how you put the lights in them.. Also these will make photography props :) thanks for sharing!
slu6alka (author)  sbhide3 years ago
It's beautiful :) Thanks for sharing this photo:)
dollywild4 years ago
Really nice. I wonder i I could spray paint them to make an ornament?
I made a TON for my wedding, and used black spray paint. They turned out really pretty. Here's a pic to show you my finished product!
(Some people were asking about double sided tape? I tried it, and didn't have much luck. I ended up using small amounts of Elmer's Glue to stick it all together, and I had really good luck with it. :) )
slu6alka (author)  dollywild4 years ago
You should try :)
kim0202894 years ago
hi i really loved this so i made one. However my question is when i glued them all together to form a ball i had a hard time gluing them together since one by one the petal would come off. I used double sided tapes by the way any tip on how i can stick them all together perfectly?
i used a hot glue gun because i didn't want to risk all of my hard work to fall apart... it stayed perfectly for me and when i was finished i put a large rhinestone in the middle of each flower!
hushy kim0202894 years ago
I have a suggestion about your concern Kim020289 based from experience.
Put double-sided tape to both surfaces you re going to stick together. You can have good reinforcement when you joined 2 adhesives together :-D
I hope this will help
<3
kim020289 hushy4 years ago
I made one for my sister as a gift then i taught her how to make one too. Now she can't stop making them. Here's my ball of blossom. Thank you for teaching me this.
slu6alka (author)  kim0202894 years ago
You're welcome :) It's looks good keep up the good work :)
Well it would be hard to stick them perfectly and I don't think that there are tips about that. There always will be holes between the petals and the blossoms. Even my model is not perfect. And about the first question you have to make 12 blossoms and every petal must stick with another two petals (from two different blossoms).
lrodie3 years ago
to make the flowers go to the video, the sketch explanation is wrong.. took me a while to figure out that... over all very easy and very cute!
sunshiine4 years ago
What a beautiful presentation! Thanks so much for sharing your hard work and great fun!
npeless4 years ago
My brother can do this:] HE made like 5!!:P
Very pretty! Thanks for sharing!
i love your work soooooooooooooooooo much >> but i would love to know how to do them
Spaces4 years ago
Can you do this with normal A4 paper?
slu6alka (author)  Spaces4 years ago
Yes, you can, but you have to cut it. It doesn't matter what the paper is, but it must be a square.
VeronicaJo4 years ago
It's alot easier to do if you make the sticky part of the notes stick to itself.
Exlent flower ball! ill have to make one soon
slu6alka (author)  knexsuperbuilderfreak4 years ago
Thank you! Show it if you like when you make it :)
Speedmite4 years ago
Great kusudama instructable. seen it before, but never saw good instructions. I think Ill make this one....
slu6alka (author)  Speedmite4 years ago
I'm glad you like it...oh and thanks for reminding me that this is kusudama, not origami
Hey that is a beautiful rose you've made here. In Origami though no glue or paste or anyother sticky stuff is used,it's all done with paper only as you can find on this site the best in the world. Check it out it's awesome and has instructions forfolding paper flowers. http://www.oriland.com/index.asp. I'm going to give this a try and see how mine turns out as it looks like a bunch of fun to do.
slu6alka (author)  Beadazzlesalas4 years ago
I know that in origami there is no glue...actually it is kusudama, thanks Speedmite for the reminding...Anyways thank you for sharing the site, I've seen it before, it's good :)
deladybex4 years ago
Oh I would love to make these! I love paper crafts and Oragami is the best.
sellulose4 years ago
Anyone knows which flower is this?
shanmash4 years ago
great work. this site is really great
CherylTX4 years ago
Ditto on the diagrams, excellent instructable. I'm trying it with mini-post-its (all I have); the gluing is tricky with those little ones : )
slu6alka (author)  CherylTX4 years ago
Thanks...I'll be happy to see the result :)
paulanorma4 years ago
will try it surely :)
pro22virus4 years ago
Beauty! Very much it was pleasant, as I want.
On the site lifted a subject concerning colors, it is necessary to consider such type also. Only it Russian, whether I do not know it is possible to allocate here
1-40 of 42Next »
