Introduction: Flush Mount Foscam Camera
Picture of Flush Mount Foscam Camera
I wanted to mount my Foscam camera directly to the wall without using the supplied mount. The mount was too big and ugly. I wanted it as clean as possible. You can purchase a universal mount kit from Foscam, but why spend the money when you can easily do it.
I used the two screws that came with the camera.
I used a:
  • drill
  • small philips screwdriver
  • 5/16" bit
  • 5/32" bit
  • razor blade
Step one:
Remove the rubber feet from the bottom of the camera. They are just stuck with stick tape.
Step two:
Remove the four screws holding the bottom plastic on the camera
Step three:
Drill two 5/16" holes to fit the head of the screw into.
Step four:
Drill two 5/32" holes directly below the bigger holes. These will be used where the screw will slide into.
Step five:
Use the razor blade to cut out the extra plastic between the big hole and little hole. See the finished hole on top of the enclosed image.
Step six:
Re-mount the plastic bottom to camera.
Step seven:
Re-install the rubber feet.
Done like dinner
MsSweetSatisfaction (author)2015-01-04
Very clever, I bet it allows you to get some great shots!
About This Instructable
1,198views
2favorites
License:
More by menerso:Flush mount Foscam camera
Add instructable to:
