Very little electronics experience is required, just a little resourceful scavenging.
Thanks to Rook's Tutorial for initial idea. BTW, that's a good link to check out if you want a (ridiculously expensive) movie-accurate prop.
Remove these ads by
Signing UpStep 1Parts & tools
You will need the following bits:
- Fuse box, about 11 x 14" -$17 @ Menards
For the window you'll either need to get a case mod window kit or:
- acrylic panel 9 x 7" - $5 @ Menards
- window molding 4' - $2.5 a foot
- LED icicle lights (white or blue) - $7 alt link
- metal cylinders x 3 - about 2 inches in diameter and 1 inch high. Small DC motors roughly that size are pretty easy to find, I used three interesting looking geared motors that have some nice detail on them. - $7.5
- translucent acrylic tubes x 3. I used some weird lab spigots I found at a surplus store - $2
- tube elbows x 3 - Say "tube elbows" out loud. pretty much anything that looks right will do here. I went through the hardware store and looked for the closest thing. - $3
- about 2 feet of yellow wire. I found some fiber optic cable the perfect diameter and color - $.75
- wiring connector block - $1
- piece of black cardboard or sheetmetal 11 x 14"
Tools
- jigsaw and metal blade
- file
- drill
- dremel
- soldering iron and solder
- electrical tape
- old style embossing label maker - label blaster and red tape
use the see through bic pens the ones that look like they are made of glass
and you can see right though them they work well
Install it the same way we used to install the old rubber-mounted windshields. :)
Wrap the rubber around the window panel. Find a length of smooth-coated wire that will more than wrap around the edge.
Place the window and gasket next to the panel. Start with one corner (your wires should cross each other at this point) and gently tug the wire, pulling "in" through the hole you want the window mounted in.
Continue to pull the wire gently through the window hole. It will pull the flange of the gasket material through the hole. When you have peeled all the wire from around the window, the window will have "installed itself." Enjoy.
That's something I picked up from doing my first computer case window mod. The company that sold me the etched window even included the washer in with the kit!
If you want to go full DC with this (or have an AC to DC converter inside, you might check out these computer RAM lighting effects:
http://www.frozencpu.com/cat/l3/g6/c77/s120/list/p1/Lighting-LED_Lighting-LED_RAM_Lighting-Page1.html
It's more than 3 LED's per unit, but nothing says you can't make your flux capacitor "pop" a little, right? If you don't like the extra ones, you could always just paint over every other (or third) one with black paint (KISS simplicity).
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=3M6440-ND
why not just make numbers of transformers and inverters things
to make a 1.21gigawatts
As far as movie accuracy goes, my christmas light hack looks good, and has multiple modes, several of which are close to the movie; I am not sure you need much else to be movie accurate in a stand alone flux capacitor. In a car-mounted capacitor you would want it to be tied into the time circuits, as well as run on 12 volts, neither of which this one can do.
I did, however, get the colors wrong, but that was on purpose.
Does it work?
