3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Flux Capacitor
DIY Flux Capacitor
250 bucks for a flux capacitor? Forget that, I did it for 54 dollars and 79 cents. It has 7 modes and it's totally freaking awesome!
Very little electronics experience is required, just a little resourceful scavenging.
Thanks to Rook's Tutorial for initial idea. BTW, that's a good link to check out if you want a (ridiculously expensive) movie-accurate prop.
Step 1Parts & tools
Parts & tools
Most of the parts are pretty easy to come by, either on the net or from a local surplus store. Links are provided where I can.
You will need the following bits:
- Fuse box, about 11 x 14" -$17 @ Menards
For the window you'll either need to get a case mod window kit or:
- acrylic panel 9 x 7" - $5 @ Menards
- window molding 4' - $2.5 a foot
- LED icicle lights (white or blue) - $7 alt link
- metal cylinders x 3 - about 2 inches in diameter and 1 inch high. Small DC motors roughly that size are pretty easy to find, I used three interesting looking geared motors that have some nice detail on them. - $7.5
- translucent acrylic tubes x 3. I used some weird lab spigots I found at a surplus store - $2
- tube elbows x 3 - Say "tube elbows" out loud. pretty much anything that looks right will do here. I went through the hardware store and looked for the closest thing. - $3
- about 2 feet of yellow wire. I found some fiber optic cable the perfect diameter and color - $.75
- wiring connector block - $1
- piece of black cardboard or sheetmetal 11 x 14"
Tools
- jigsaw and metal blade
- file
- drill
- dremel
- soldering iron and solder
- electrical tape
- old style embossing label maker - label blaster and red tape
189 comments
1-40 of 189next »
Nov 22, 2011. 10:42 AMHackerBilly says:
If you need the translucent acrylic tubes and can't find any
use the see through bic pens the ones that look like they are made of glass
and you can see right though them they work well
Nov 11, 2011. 5:03 AMDuke Bushido says:
There's a much easier way to install the rubber window grommetting material:
Install it the same way we used to install the old rubber-mounted windshields. :)
Wrap the rubber around the window panel. Find a length of smooth-coated wire that will more than wrap around the edge.
Place the window and gasket next to the panel. Start with one corner (your wires should cross each other at this point) and gently tug the wire, pulling "in" through the hole you want the window mounted in.
Continue to pull the wire gently through the window hole. It will pull the flange of the gasket material through the hole. When you have peeled all the wire from around the window, the window will have "installed itself." Enjoy.
Jul 16, 2011. 2:00 PMbshut says:
A good tip, to help get your extra gap right, for the window molding, is to use a 1/4" flat washer. Place the acrylic (plastic) where you want it, put the washer up against the outer edge of the window, and place a pencil/pen/Sharpie (crayon? LOL) inside the washer. As you trace around the edge of the window, the washer will give you just about the perfect spacing, plus it rolls really nicely around the perimeter of the window while you're tracing.
That's something I picked up from doing my first computer case window mod. The company that sold me the etched window even included the washer in with the kit!
If you want to go full DC with this (or have an AC to DC converter inside, you might check out these computer RAM lighting effects:
http://www.frozencpu.com/cat/l3/g6/c77/s120/list/p1/Lighting-LED_Lighting-LED_RAM_Lighting-Page1.html
It's more than 3 LED's per unit, but nothing says you can't make your flux capacitor "pop" a little, right? If you don't like the extra ones, you could always just paint over every other (or third) one with black paint (KISS simplicity).
Jul 10, 2009. 7:17 AMshanghei says:
The clear tubes are 3m applicator nozzles, lo and behold just take out the mixing part inside
Apr 3, 2011. 3:42 PMwhakker711 says:
How do you get the mixing part out??
Sep 19, 2009. 6:46 PMboston09 says:
where can you get them?
Sep 21, 2009. 6:03 AMboston09 says:
thanks
Sep 16, 2008. 6:31 AMcaterpillergrrl says:
You, my friend, are my newest hero! this is pretty fantastic! And to think, I was just searching for a "flux capacitor...fluxing" ring tone! This was a happy page to stumble upon.
Nov 21, 2008. 4:05 PMolli_outatime says:
whoah... not even in my wildest dreams did i imagine a flux capacitor besides in universal studios or on the set of the movie... me and my friend were jokin about makin one... i'm olli. im a girl in 7th grade who is totally oldschool and no1 (besides the adults) has the same interests as me. they say jonas brothers - i say journey. they say high school musical 1,2, & 3 - i say back to the future. they say jesse mccartney - i say bryan adams. which is why i mostly talk 2 adults. plus, im not some mindless kid; i can carry on a conversation about the economy or a political debate.
Dec 7, 2009. 4:07 PMMorriscow says:
 i agree except for the jonas brothers -- THEY BOTH SUCK
Feb 25, 2011. 4:07 AMCrushinator says:
Uuuuuhhhh I think there are three Jonas brothers.
Jun 7, 2009. 7:21 PMclovervidia says:
yay someone thinks like me. w00t
May 1, 2009. 7:23 PMphant0m_sp00f3ra says:
i have the same feeling. actually i have almost no contact with my own school generation, i spend most of my time talking with the people 1 year ahead of me :P and we talk about some stuff my own co-graders don't give a crap (politics, quantum mechanics, pc we're geeks u know :D) i understand u and i only can encourage u to be urself no matter what happens :D as apple said think different!!! LOLOLOLOL (btw im 17 :P)
Mar 13, 2010. 10:56 AMclovervidia says:
 I say do math like this. google the answer. What? Apple said think different?
Mar 13, 2010. 4:50 PMphant0m_sp00f3ra says:
 Not truly apple it was TBWA/Chiat/day agency :)
Jun 7, 2009. 7:22 PMclovervidia says:
g33k pwr! w00t
Jul 12, 2009. 12:26 PMDerin says:
woooooot
Jul 12, 2009. 12:27 PMDerin says:
there is this other guy in my grade we are the most geekiest people in 6th grade we spent our breaks in the computer lab the whole year in 5th grade
Aug 7, 2009. 4:46 PMclovervidia says:
we were the geeks of 6th grade too. in 7th grade, every single lunch we usually were in the library doing stuff. and i was the only one to even eat lunch. lol
May 23, 2009. 2:52 PMultrakill says:
:O people... ...like me? hmm... ur probably in america aren't you. that wud be simply TYPICAL. *cries*
Jan 20, 2011. 5:50 PMSickman9 says:
Do you have a part number or manufacturers name of the enclosure? I can't seem to find one for as cheap as you did. I couldn't find one on Menard's web site.
Nov 7, 2010. 3:12 PMbuffalobillshater411 says:
hey its missing the "shield eyes from light" sticker
Dec 30, 2010. 5:15 AMmaxis75 says:
your right
Dec 30, 2010. 5:08 AMmaxis75 says:
does it really work?
why not just make numbers of transformers and inverters things
to make a 1.21gigawatts
Jun 17, 2010. 4:59 PMJ-Five says:
1.21 Gigawatts What the hell's a Gigawatt!!!!
Aug 6, 2010. 4:35 AMsakabato777 says:
1000000000 watts or 1 million big lightbulbs
Jun 7, 2010. 12:31 PMRichard J. Zuckerwar says:
I just purchased a 1983 DeLorean. It only has 1300 miles on it. Could I purchase a Flux Capacitor from you? If so how long would it take for delivery? Richard J. Zuckerwar Misterz1@aol.com
Apr 29, 2010. 7:09 PMEragonShadeslayer says:
So are you saying that the circuit diagram from Rook's page is for programming the self built circuit? which is more movie accurate, Rook's or yours? I don't know where there is a video of Rook's in action.
Mar 29, 2010. 5:38 PMJ-Five says:
Does it work?
Mar 20, 2010. 5:00 PMflavors23 says:
i hav a better way to do it n its jst the way the one in the movie was made.  u need 3 identical old CRT type t.v.s n rip out the things from inside connected to the tube that look lik suction cups.  keep them connected to the circuit boards so wen u turn it on they each generate 20 or 30 kilo-Volts.  Then get some large xenon flash tubes pro photographers use for the tube that u will c.  put them in the box as u do in theis project with your straw things n hook the suction cup looking wires to the ends of the xenon tubes.  then solder the other end of  the tubes all to one wire and run the wire to a ground on the circuit board.  wen u turn on the circuit boards (apply 110 volts) the xenon tubes will light up with bolts of lightning inside. it looks really awesome.
Jul 9, 2009. 8:00 AMtargus says:
i finished my flux capacitor about a week ago, right now ive got it mounted in my ambulance at work. best thing ever.
Jan 9, 2010. 10:35 PMstevenschubert says:
how do you plug it imto the vehcle?  i need a plug for my cig lighter outlet.
Sep 19, 2009. 7:44 PMMACKattacksnipe says:
Go MARTY lol Back to the Future
Sep 22, 2009. 8:50 PMPeltierMan says:
Marty !!! - - Come back !!!
Sep 20, 2009. 1:15 AMI died with my head in a washing machine says:
shame it doesn't work
1-40 of 189next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
65
Author:sponges
