Step 3Wire it up!
This part entails pretty minimal soldering/electronics experience. You're going to need two switches, one to toggle the whole thing on and off, and one to switch modes - a momentary on/off.
The momentary switch just replaces the built in one, wired directly under it on the circuit board. The power switch goes between the wall and the circuit, using either wire.
Be sure to use electrical tape or heatshrink tubing to cover the exposed wires, and that none of them come in contact with each other or the sides of the fusebox.
I just used the built in holes on my fuse box to mount the switches. Pretty convenient.
For now you can just let the LED wire dangle.
As far as movie accuracy goes, my christmas light hack looks good, and has multiple modes, several of which are close to the movie; I am not sure you need much else to be movie accurate in a stand alone flux capacitor. In a car-mounted capacitor you would want it to be tied into the time circuits, as well as run on 12 volts, neither of which this one can do.
I did, however, get the colors wrong, but that was on purpose.
