Fly Fishing Reel
378
9
Posted
Introduction: Fly Fishing Reel
making a fly fishing reel
Step 1: Step # 1
I cut a round wheel out of solid hardwood approx 3 3/8" or 8.5 cm (metric) thickness can be 7/8" up to 1 1/2" you choice
drilled 4 holes USING 1/2" bit and flared to 3/4" in it as shown this will be my inner wheel where the line will be -- there are 4 smaller guide holes for ss countersink screws
the wheel will then have 2 sides made of a sheet of aluminum as shown above
cut out will be a 5"1/2 or 14cm (metric)
Step 2: Step # 2
then cut the wheel out of a sheet of aluminum using a buzz saw
aluminum thickness 1mm or better 1.2 mm
then I used the router to give it a perfectly round shape
the wood play wood form was used to make 2 routed identical shapes
shown above the aluminum cut out
Step 3: Step # 3
I start assembly of both aluminum sides to the wood block
there will be another hole drilled for the handle or if you like 2 handle drill 2 you can also use it as counterweight instead of a wood handle were you will need a solid heavy material the as a counterweight
Step 4: Step # 3
the wheel assembled
I cut out and shaped an L bracket as shown with 2 sprockets to fit the reel
the main shaft will fix to the L-shaped firm and I used a stainless steel bolt for that
a dab of gel epoxy will prevent it from moving and will hold it in place on the other end a
the nut will be installed or a lock nut but it should be left shy of 13/16 to allow movement of the wheel
and there you have it done I will later add a heavy brass balance on
opposite side utilizing and old knob shipping it to 1/2 dome look
there are 2 other examples I am showing that I did with 2 handles instead of one
Step 5: Step # 4
the 2 other examples
the one that is sprayed to look anodized aluminum is spray I picked up at the auto store which gives that metallic see-through look - or anodized look
the other las few are a different design with different patterns but using a handle that comes from the center extended more that the wheel this give more torque force
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Gluten Free Challenge
