3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Flyback Driver circuit.
This is a instructable that contains scematic and pictures of a single transistor flyback driver.
stuff's used:
1x breadboard
1x NPN transistor (with heat sink and a fan)
1x 22 Ohm resistor
1x 220 Ohms resistor
1x transformator (or round ferrite core) with same amount of windings
1x flyback transformator
1x 12 - 15V Powersupply ( i use a battery that gives 15 volt, 400 mA)
And some wires.
Step 1Scematic of the driver
After i tryed the flyback driver with the primary and feedback windings on the flyback's ferrite core, i thought: *why not try t o use a tiny transformator with same amount of windings to oscillate the process, and so i found out i would try it, and  i got 10 - 15Kv More from the flyback transformator by doing this, so i figured i would make an instructable.
i think the picture is somewhat blurry cause of the size, so il point out the important stuffs here:
* The transistor must have a heat sink.
* Before you put 12 volt in, test the circuit with 3 - 6 volts, and make shure that the transistor doesn't get overheated
(I currently run the circuit with 15 V , 400 mA, and still i cannot feel any sign of heat on the transistor)
i get around 50 Kv from this.
If you have any questions, just ask.
60 comments
1-40 of 60next »
May 9, 2012. 7:48 PMdaone1 says:
your circuit didn't work with 2n3055
so i changed a few things in the circuit (still kept 1:1 trans) and it work perfectly
i could drive a plasma globe at 18W input (9v, 2a) which was impossible before
that's amazing with 1:1 trans
happy sparkin~
Feb 13, 2012. 10:57 PMOVERLOADED says:
I have been using this good transistor it a toshiba D2586 I am able to run it on 12-18volts with no problem but when i try 36v it either stops right away or it works for a few seconds before I hear it whining down and die? any idea why its not able to take this voltage? I do have the datasheet for the transistor if you wnat to see it , also can you recommend any other transistors that can handle higher voltages?
Feb 14, 2012. 11:15 PMOVERLOADED says:
well I wanted to try to see if it can handle it, I looked at the datasheet and it says about 5A DC or 10A pulsed, but I have no idea what the max voltage or current input should be? it says that Vcbo is 1500V, Vceo is 600V, Vebo is 5V,collector current is 5A DC and 10A pulsed,base current is 2.5A,,,so I have no idea what these mean exactly I know what they are but still? so maybe your more familliar any ideas? I also got about 3 diff TV PCB's with lots of good stuff on them that I can always salvage, and most good transistors come from the same board you find the FBT on most ppl dont know this. the toshiba trans i got has not died yet when so many others have at 36 volts. I also google the parts but some are impossible to find same goes for FBT's.
Feb 20, 2012. 3:16 AMOVERLOADED says:
yes i use two 18 v power tool bats or sometimes a 12v adapter with 500mA
Feb 15, 2012. 5:11 AMOVERLOADED says:
well if you want i can email you the datasheet on it to save you time.
no i did not use your schematic, but now that you mentioned it yes i was using regula thin wire unspliced I was thinking about this before and its probably the problem its very thin wire not mag. there is no heat cause i was runing it on 12v but it was not working with ext feed and prim, but the ext prim worked in combination with internal feed.
Feb 16, 2012. 1:08 PMOVERLOADED says:
ok great so have a look at the datasheet and tell me what you think make sure its entitled 2SD2586 thats what my datasheet calls this trans but on the actual trans it dont say 2S? oh well i am sure its still the same one, what does your title say?
yes I used the thin wire cause it was handy at the time and easier to wind thru the slot of the ferrite.
the resistors I am using are 220R 5W and 22R 1/2W ,,i couldnt find 2W. I hook them up along with a single trans to my FBT, so its a simple circuit like the ones you have seen many times on the net.
I am not sure what the resistors part of the simple circuit does? i think its a voltage divider but no one explains as to what it does or how the current actually flows in the entire circuit, usually they only explain the feedback thing, can you please explain to me how the entire thing works along with what the resistors do? please explain a simple circuit not yours as it may be a little diff.
Feb 16, 2012. 4:37 PMOVERLOADED says:
yes that what i know too, but the resistor end of it I have no idea?
I think for sure it makes the cycling of the feed back go one way rather than another because one resistor is higher value than other but why even use the other then? ohhh well.
i havent fooled around with diff resistor values because i need to understand what they are doing before i attempt to make changes that make sense to me, for sure once i know then i can def make improvements if necessary, same goes for improving the trans maybe by using diodes that have a volt leakage of enough to run the trans but protect it from high return spikes and over saturation then i could run it up to 36 v perhaps. but everything i am saying is just hypo as i really have no idea of the exact workings of this circuit.
maybe we can chat on gmail instant chat? do you know how we can exchnage email add? without leaving them here? i have done this before with someone else but not sure cause he did it for me.
Oct 14, 2011. 7:04 PMaclark17 says:
I haven't gotten this to work, it turns my 12v supply into a pulsed dc voltage, max of .71v, wth.
Can you be more specific about your transistor?
Oct 18, 2011. 9:21 AMaclark17 says:
I found out I was using an LPS supply, Ive since converted a computer power supply into a lab supply, works great, but I had in a TIP3305 transistor, was so hot it burned my fingers xD
I happen to have an epitaxial npn I was using before, Ill try it again and post what I find, with the new supply, the circuit seems to be working normally now, aside from the transistor heat (at only 3.3v too!!)
Thanks for your response :D
Feb 18, 2012. 5:22 PMOVERLOADED says:
when there is small voltages there is usally higher current ( amps).
Oct 18, 2011. 6:29 PMaclark17 says:
Yeah I have an epitaxial that I think I got actually from the CRT TV I got the flyback from, along with various heatsinks for them, but I salvaged also from an old Pentium III cpu the heatsink/fan combo and drilled a mounting hole and threaded it with a tap wrench, so I planned on fixing it to that, but ran into power supply issues, so I took it off an tried various other transistors (before realizing the issue was power and not the transistor power dist) with a regular transistor/FET heatsink without a fan. It got WAYYYY hot, but it wasn't the epitaxial, just a random power transistor I picked up from radio shack on a run. It has pretty high specs and Im not sure its best suited for this application, so when I get around to trying out the other ones I have, if I have any different results I'll share :)
Thank you for the instructable, it and the schematic were fairly easy to follow, and not complicated, but gives great results, and that's how its done! :D
Oct 20, 2011. 4:25 PMaclark17 says:
Nothing too specific, for me most of this stuff is more about the making of it and not so much the use ;)
But I do want to make a plasma speaker to mess around with :D
What do people usually do with things like this? lol
Feb 12, 2012. 2:03 AMOVERLOADED says:
So basically you found that a 1:1 transformer acts like a feedback so you have now an external feedback to drive your transistor but how does this improve it ? is-int the feedback in the FBT good enough? also are you using the primary of the FBT or did you wind your own? I have found that if you put a wire between the return and the wire that goes to the voltage divider it improves the arc also another discovery I made to drastically improve your arcs( brighter, bigger, longer,louder) is to hook up a capacitor in parallel between your output wires I made a small simple homemade one and am now getting about 90kv.
Feb 13, 2012. 10:37 PMOVERLOADED says:
Yes I guess it depends how you want to run it, most ppl do preffer to make there own external winds as they can adjust them to there liking, its a good way to experiment, I have tried making 10p and 4f ext on my FBT and used a 2n3055 but it did not work, in fact i had to end up using the FBT feedback in order for it to work with my other transistor, the 2n3055 just never worked for me?. right now I usually run my FBT from CFL circuit it works great and adding a homemade cap really gave awsome high rep rate sparks that look like the ones used in a tazer.
Feb 14, 2012. 11:01 PMOVERLOADED says:
yep but I like to see what can be done with the winds in FBT itself, I like to see what they can do with simple transistor drivers, CFL or electronic ballasts, have you ever tried hooking an EB to the primary of your FBT? they produce great results because they output about 500-600VOC with the right freq to run the FBT I think around 15KHz in a square wave pattern and since they are self resonating you dont need to hook any feedback , simply hook it directly into your mains and into primary of FBT, but make sure the FBT you use has at least 11 pins on the bottom, they only seem to work well with those types.
Feb 15, 2012. 5:12 AMOVERLOADED says:
EB is what I use short for electronic ballast
Feb 15, 2012. 3:01 PMOVERLOADED says:
thats ok im happy your good with what you got, but if you want even longer purple arcs then get a FBT with only 11 pins on bottom (10 in U and 1 outside) and hook it to an EB either a CFL circuit with high wattage or you can buy EB it gives about 600V .5-.9A with proper square wave pattern, feed this to you primary and your in business. dont run it long as it may heat FBT , one guy had his in oil.
well you should use at least 12-18volts if not more depending what your circuit or transistor can handle and about no more than 2 amps since FBT are limited to about that anyways or was it 2-4A ??? more amps means a hoter quiet purple arc, not sure if more amps means more voltage on output? but if you pass it thru cap youd get amaizing sparks (fat,long,brighter, louder and depending on cap high rep rates looks continuous.
Feb 13, 2012. 11:12 PMOVERLOADED says:
Your FBT looks big is it two of them or just a big one? it looks like it may be one of those that have internal cap.
Feb 14, 2012. 11:05 PMOVERLOADED says:
well it looks like it has two barrels? so I figured it might be one of those that have cap inside, and you say it is, but you say you have the option to use the cap or not ? hmmm really I tought it was hooked to the cap internaly so you have no choice but to use the output from thr cap,, Ok well why dont you try it then I am sure you will get better arcs or sparks.
Feb 15, 2012. 5:18 AMOVERLOADED says:
first of all how many pins on the U pattern?
ok so you got 2 extra pins aside from U ok and these are for cap?
so your telling me that you have the choice to have arcs thru cap or without cap?
all I know is that if you have a cap in parallel to the HV out and HV return then you will get better sparks so try connecting to internal sparks and see what happens ,,if cap is in series it will not work but i believe its in parallel.
Feb 15, 2012. 3:14 PMOVERLOADED says:
wow I never seen one like that but ive only seen two so far lol
you should try it for a second and see what happens, why are you worried? tell me what u run it at now, give me input voltage and amps and I assume ur still using same circuit right, if its 12v then dont worry , hook the cap on and see what it looks like , but judging from your picture they actually look like sparks already coming from cap?
i think your cap can def handle it, but you can always hook an external cap to the output leads and bypass the internal cap for now.
I would not worry , on mine I use a CFL circuit that outputs maybe 1000v and maybe 380mA , it says on the lamp 120v 380mA 23W it looks ok by itself I get an arc about 10mm long then it puls to 15mm and becomes sparks, but when i hook it to cap it gives about 20mm sparks about .75" on start very intense ones . how long is your arc now? pls make sure u get precise measurements in mm.
1-40 of 60next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Mahitchima
Transistors may sometimes work nice as firecrackers.
