3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Flying Fan
Flying Fan
This fan hangs from its extension cord and flies around in circles. You can add accessories like a toilet-paper dispenser, a robotic hand for giving you high-fives, or as many cupholders as you want. To see video of this gadget in action, watch the Robot/Art movie.
Step 1The Slipring
The Slipring
You can of course hang any fan from its extension cord and let it fly around. Eventually the cord will twist too much, short out, sparks will fly, and the fan will wing off into some corner of the quonset hut while the campers all shriek with delight. I think you can get a merit badge for turning in other boyscouts who do that.
This particular project uses a "Rotating Electrical Connector" a.k.a "slipring" so the fan can fly indefinitely.
Mine came from Mcmaster-Carr http:www.mcmaster.com it is part# 7631K51 it costs $27.54 plus some extra for couple of connectors. The one I'm looking at right now has the markings "Mercotac 205 T95". It contains two little puddles of mercury with the contact wires dipped into them. When you order one it comes with a little container to ship it back to the manufacturer for disposal. I've built a couple of flying fans containing these gadgets, one of which has flown for more than a decade. Of course I now have no idea where the return mailer is, but it sure was a nice gesture.
I used to make my own sliprings which were either unreliable or too much work.
There are other cheaper sources of sliprings. Some types of electric motors have them built in. Some vcrs have them for making contact with the rotary head assembly. You can even use a "telephone line untangler" if you find one that will carry enough juice for your fan.
21 comments
Jan 4, 2008. 9:16 AMelnorte says:
Will it fly in the direction of my choice at the equator?
May 11, 2008. 10:03 AMkillerjackalope says:
go to the equator and flush a toilet...
May 12, 2009. 10:34 PMsteve000 says:
it explodes and flushes out of the toilet
May 13, 2009. 4:38 AMkillerjackalope says:
And that's how a zebra is born...
Apr 1, 2010. 10:21 PMthe z0diak says:
and bingo was his name-o
Feb 5, 2008. 5:58 PMMatrixEagle15 says:
hahahaha
Feb 8, 2008. 4:45 PMSharku says:
cool and random nice maybe I should make one and add some wings if i make it ill post some pics
Dec 25, 2007. 2:13 PMtechnodude92 says:
reminds me of junkyard wars! roflcopter
Dec 16, 2007. 4:58 AMbedbugg2 says:
wow these are so incredibly random!
Nov 22, 2007. 8:07 AMthe_burrito_master says:
used to want these things so badly every time I saw on in the toy store I said. "mom can I have that please!!!"
Oct 17, 2007. 8:43 PMFletcher says:
Speed control for DC-powered fans of less than 15 volts:
555-based PWM speed controller
This is a minor modification to the common 555 timer circuit. Provides true pulse width modulation speed control with a minimum of cost and parts. Built one like it today, was pleased with it's performance.
Oct 2, 2007. 7:53 PMinstructa-fan says:
5 strips of toilet paper+1 foot of tape+1 ceiling fan=this thing times 5....... decent instructable though, i mean someone could have just wasted 5 bucks at the mall....
Aug 3, 2007. 9:56 AMkillerjackalope says:
you could keep the more rudimentary speed controls from your fan in the first place and have a 3 speed flying toilet roll dispenser also I have though of an interesting use for this using the same rail system from those movable halogen lights make a live track round the room using fairly stiff metal wire or copper piping and support it from the ceiling on rubber blocks that site below the track put 2 arms on the top of the fan and run the connector wires from the power up it to conductive wheels, use motor brushes for connecting the wheels to the power you now have a flying fan train capable of delivering cool drinks and toilet paper even use a 12volt motor and use the transformer from those lights or wire it into the ceiling and use a dimmer switch so you have speed control sorry about my uber long comment just saw a whole lotta potential for wasting time watching a fan make its way around the room
Aug 17, 2006. 9:12 AMleevonk says:
If you don't mind about wasting power/heat, you can just put a potentiometer (which is good enough for the amount of power you're using) between the power supply and the fan to adjust speed.
Jan 5, 2007. 6:20 AMinfiniteregress says:
possible problem with the pot is that with the power running through 24/7, it'll (as you said), generate a lot of heat. The design of a pot only lets you use one end of the resistor that inside, and that end might burn itself out. I have absolutely no idea how long it'd last, but it'd work...
Sep 25, 2006. 2:02 AMFROOZ says:
but haveing a spinning tolietpaper holder would be pretty cool... oh and also, those dryers are pretty damn captivating
Aug 16, 2006. 10:16 PMWade Tarzia says:
This is too cool....I saw it in action once, when I first stepped into the room and met the maker. I almost didn't know how to start the conversation or divide my attention between the ceiling and the social situation. I hope I didn't seem rude, but that's what you get when you decorate with animated flying art ;-) Glad to know now how you managed the power transfer -- a mystery until today.
Aug 22, 2006. 4:08 PMleahculver says:
Met the maker (Tim) or your Maker? That thing is pretty dangerous. It's really captivating though, like the dryers at a laundromat.
Sep 11, 2006. 1:49 PMWade Tarzia says:
Yes, just like the dryers. I wonder if that is where Tom Disch got the idea for the "fairy traps" in his excellent SF novel, "On Wings of Song"? Tim's flying fan would probably catch some fairies (which are in this case machinery-enabled disembodied mind-essences flitting about and spying where they oughtn't).
Aug 17, 2006. 4:30 PMa-sam says:
it would be hard to use toilet paper while it's spinning, but nice project anyways.
Aug 17, 2006. 11:39 AM0.775volts says:
they sell dimmers for inductive loads at home depot and such. you can just look for the ones that say they can be used for fans/motors. couldn't you adjust it's speed by varying the length of it's tether?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1250
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
