Step 2Cut mount for cutter
iImage Information
use a marker to outline the hole you want to cut out, i used the center hole for the mount hole. as you cut out the hole with the hand cutter keep the circle that is left this will be used later on for to mount the cutter. you need to cut a smaller hole in the middle of the cut circle you just cut. can see in the picture that you need to cut a piece off to make it a circle. Then make sure that the hole is big enough to fit the small shoulder on the cutter like in the pic.
