3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Foam Cutter table
Step 3Mount cutter and make reccess in foam
mount cutter and make reccess in foam
next you need to cut a large hole in the bottom chunk of foam where the handle of the cutter will be. the end of the cutter that the power supply plugs into will be at the bottom of the box so you need to cut a hole in the bottom of the box where you will add legs to hold it up so you can plug it in.
to mount the cutter put the mount ring on, but don't glue it, then place the mount in a place where the edge of the metal mount piece on the cutter is flush with the top of the foam. mark it with a marker and glue just the ring in place and add a few pieces of scrap foam to reinforce the joint.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:FoamCrazy
