Step 4Mount cuter and feet
iImage Information
after you mount the mount ring it is time to hot glue the cutter in the mount. start by sliding the cutter on and making sure it is straight up, then add a few dots of glue to the bottom of the ring and put it in, hold the cutter and check the alignment as the glue dries. after that make sure you get rid of the kitten that might be inside the box before you put the foam back in. (JK! =P) then cut a hole in the box for the plug on the cutter like in the picture. and cut a hole in the top for the cutting rod to go through.
