Introduction: Foam Plate Plane
Are you tired of buying overpriced parts for your rc plane? Well this is for you I have saved over $50 with this plan
Step 1: Get the Materials
You need the following things, 1. Old styrofoam plate 2. Old airplane part 3. Hot glue You also need siscors
Step 2: Get a Templet of the Part
Tape up the old part as best you can or just design a new one
Step 3: Start Drawing
Trace or draw the part on the plate make sure you draw where the hinges are
Step 4: Cut Out
Cut out the part be carful don't cut where the hinges go
Step 5: Make Hinges
To make the hinges just run it over with a pincle a couple of times to push in the styrofoam but don't go all the way through and then test it
Step 6: Add Control Horn and Wheel
Mark where the control horns go and the wheel and install just like you usually do
Step 7: Install
Mine was a perfict fit but if yours is to thin you might have to ca some plates together to get it right but install like normal and go fly
Instructables Green Design Contest
Epilog Challenge V
