3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Foam RC Airplane
Step 3Making the wing control surfaces
I do limited stunt flying so all I use are ailerons and the elevator. You can make a rudder for more advanced flying but I left it out of this instructable but you can apply the same techniques. The simplest control hinge is made from packing tape.
Using the jig saw cut both ailerons at a 30-45 degree angle where the control surface meets the wing. To make the hinge, mate the control surface to the main wing body at the cut angle and apply the tape along the length. Then fold the control surface the other direction and tape under side of the wing and aileron.
Next, slide the wing through the slot in the airframe. Apply glue to the center of the wing and slide in place. Allow the glue to dry then repeat the taping procedure on the other side of the wing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:tak145
