3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Foam RC Airplane
Step 8GO FLYING!!!
You are done. Go flying. These planes are light and have very little surface area resistance so they fly well. With the right brushless motor these planes can takeoff vertically right out of your hand.
8 comments
Aug 11, 2009. 9:27 AMcillianm564 says:
I want to build one which material would be better balsa wood or foam
Jun 22, 2010. 11:34 AMMadrias357 says:
Foam is easier to fix, and if you ask me, more fun. A crash with foam means tape and glue. A crash with balsa wood means a full repair job.
Aug 30, 2010. 5:46 PMlimppimento says:
Couldn't agree more. I love to build but I would rather fly than repair. A little tape or foam glue is hardly a repair and your up in three minutes. Although, Just for the sake of arguement, and to be fair, Balsa repair really is not as bad as some would think(for a minor crash), but it does end your flying for the day.
Aug 31, 2010. 12:25 PMMadrias357 says:
Exactly. A balsa plane crash ends your day. Foam planes, it's time to get out the foam-safe super glue and the fiberglass reinforced tape and stick the pieces together.
Sep 17, 2011. 6:06 PMarpruss says:
Newbie question: What is the foam safe super glue?
(I've had good luck gluing foam with Gorilla glue. I also tried Shoe Goo when I was out of Gorilla glue--it ate up an inch of foam, oops.)
Sep 19, 2011. 2:59 PMAndyGadget says:
UHO POR is the glue to use.  This is a contact adhesive which doesn't eat the foam and is great for other jobs too.
Aug 30, 2010. 5:41 PMlimppimento says:
First, tak145 thanks for the contribution. I have noticed there are several negative comments as to the quality and design of this plane. Based on my experience of 12 years of experimental r/c design flight, and I still learn new things eveyday, I would like to make a few observations. 1) I have never come across a plane that would not balance unless it was due to a horrible design issue. That doe not exist here. These plans are nearly identical to several commercialy produced kits on the market. 2) This is a 3D profile style plane. I have built several out of 3/16" foam core WITH bamboo dowel supports for the wing. If you want a plane you can run up to max power on you throttle and yank back on your elevator, and keep it in one piece, don't build this plane. Tak145 may not agree, but then again, he made his out of 1/2" foam. 3) could you put a nitro on this. yes but see point #2 above. When I first started out flying all I had was a 2 channel radio, a $3 walmart foam glider, amd a cox .049 engine. So yeah its possible. The important thing is to experiment. This is a great guide for getting you started but dont look to insult someone if you base your battery position off of someone elses picture and it doesnt balance. Ask, don't insult, especially if you went though all the fun of building this then scrap it because of a kink or because you thought you were building a HI-PO Jet. Thanks.
Jul 6, 2010. 12:22 AMyuvraj kanda says:
ITS ONLY JUNK NOTHING
Feb 18, 2010. 11:25 AMrodneyroy says:
ive looked at these plans before, and they look easy enough. but im not sure if i would trust them, becaouse i  made the bipe from the same website and it didnt fly very good. maybe it was the kind of foam. who knows.
Jul 18, 2009. 12:57 PMstumpffy345 says:
thats cool i may build one of these
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:tak145
