3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Foam Walkalong Glider
Step 2Cut out Piece of Raft-R-Mate Material
the Owens Corning Raft-R-Mate product can be found in the insulation department of most home building supply stores. Alternatively, thin (1mm) depron or other foam may be used. If the material is already in sheet form, this and the next step on thermoforming the Raft-R-Mate into a sheet can be skipped.
The Raft-R-Mate product does not come in nice flat sheets and must be cut and thermoformed. The pink foam is cut so all bends are parallel to each other. This makes thermoforming the material into a flat sheet easier. Here's how to cut the foam:
2 comments
Sep 24, 2009. 4:51 PMcyuen says:
The foam sheet is big....i dont know if i need that much...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
65
Author:walkalongaviation
