Foam Cutter
Published
Introduction: Foam Cutter
We are Otte Lowagie, Arnou Verfaillie and Mathijs Vanbeselaere from the university of Ghent campus Kortrijk. We study industrial engineer elektro-mechanics.
We designed this project in case to DIY. What follows is a brief summary of how to create a foam cutter who can make square waves out of a block EPS (expanded polystyren). It is divided into a few steps, with 3 particular parts: the frame and the horizontal and vertical movement.
NOTE: as material we propose MDF, so you can easily laser your parts. The machine is created for other materials as well but it increases the cost price and work. The other standard parts as screws you can easily get in a DIY-shop.
Enjoy!
Step 1: The Horizontal Movement
The assembing of the horizontal movement can be divided in 2 steps.
Parts of step 1:
Step 2: The Horizontal Movement
Assembling part 1:
Step 3: The Horizontal Movement
Parts of step 2:
Step 4: The Horizontal Movement
Assembling part 2:
Step 5: Table
The horizontal movement of the foam cutter is connected with a table, who carries the EPS. The connection is discribed in another step, but for now the parts for the table:
Step 6: Table
Assembling table:
Step 7: Wheelsytem
The table has to be moved, so a system is needed to transport it. In this case, we chose a wheelsystem.
Wheelsystem - parts:
Step 8: Wheelsytem
wheelsystem - assembling:
Step 9: Vertical Movement:
Again, as the horizntal movement, this part of the assembling is divided in 2 steps.
Parts of stap 1:
Step 10: Vertical Movement
Assembling step1:
Step 11: Vertical Movement
Parts step2:
Step 12: Vertical Movement
Assembling step2:
Step 13: Railsystem
The vertical movement has to pull up a filament that melts the square waves out of the EPS. This is assured by a railssytem, which is connected by a U-profile with the vertical component. In later steps we see the exact meaning of this. First of all, we make these railsystems.
Parts needed:
Step 14: Railsystem
The assembling:
Step 15: Pulley
We can almost assemble these individual parts, just one small step left. The horizontal movement is connected with the table by a string. The vertical movement is also connected with the U-profile by a small string. The connection string-threaded spindle is made by pulley wheels. We create per movement 3 of these pulley wheels, which makes it possible to play with the size of the square waves.
Parts needed:
Step 16: Pulley
The assemblyschemes for the pulley wheels are similar.
This is an example:
Step 17: Box
The final step of the assembling can start. Now we just have to put all the individual steps together. We work in a few steps.
Parts step 1:
Step 18: Box
Assembling step1:
Step 19: Box
Assembling step 2:
(Add the bolt (nr 4))
Step 20: Box
Parts step3:
Step 21: Box
Assembling step3:
Step 22: Box
Assembling step 4:
(Add the length-flank with railsystem in step 3)
Step 23: Box
Parts step 5:
Step 24: Box
Assembling step 5:
Step 25: Box
Parts step 6:
(Note: Nr4 are the railsystems who are already integrated in the previous steps.)
Step 26: Box
Step 6 assembling:
Step 27: Box
Parts step 7:
(Add the horizontal movement and pulley wheels)
Step 28: Box
Assembling step 7:
Step 29: Box
Parts step 8:
(Note nr8-10 are the components of the vertical movement and are not added in the partslist)
Step 30: Box
Assembling step 8:
Step 31: Box
Parts step 9:
(Note: nr7 is the vertical movement, assembled in the previous step)
Step 32: Box
Assembling step 9:
Step 33: Box
Parts step 10:
(Note: nr 4 is the wheelsysteem, made in a previous step)
Step 34: Box
Assembling step 10:
Step 35: Box - Final
So, after you added the table and if everything went fine, this will be your result.
Step 36: Final
As example: this is our foam cutter, cutting a square wave.
NOTE: this is only woth 1 L-piece on the table.
Comment if you have questions ;)
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    5 Comments
    Neat! Do you have a video of it working?
    The video has been posted
    I would also like to see her in action, but try as I might, I see no video linked or embedded. Any guidance would be welcome. Good luck!
    FOUND IT! The link is in Step 36 titled "Foam cutter - Step #36(480x320) 17 KB"
    http://ontwerptoolsii2013teamemb1.blogspot.be/
    This is a link to our blog, but it is written in dutch. You can scroll down to see some vids from start to end. I hope i can help u with this and i'll post a better movie soon on the blog!
