Foamboat construction
Go from sketch to model to fullsize solid boat hull in easy steps using my FOAMBOAT method. Wrapping fiberglass over a pre-carved foam male mold is not new, it is regularly used to make custom surfboards. What I offer is a way to shape a mold that will yield smooth, symmetrical and repeatable results for those of us who do not have a sculptor's eye and who do not want to get covered in foam shavings and dust. I developed the technique for making long, narrow solid boat hulls, but it could be adapted to make all kinds of shapes and molds for other purposes. The photo is 1-inch to the foot drawing of my first pontoon, P1, used to work out the techniqes, and it is all that is needed to create all the components for a model and, scaled up, for the 15-foot hull itself. Vary the sizes, shapes and spacings of the lines on the sketch to create hulls, or other objects, that suit the user. To see my related Instructables, click on "unclesam" just below the title above or in the INFO box to the right. On the new page that appears, repeatedly click "NEXT" to see all of them.
Unclesam
Step 1Trace drawing onto components
These are all the parts for a model of P01, the very thin plywood, from hobby shop, cut directly from the drawing, bats of foam cut large enough to enclose the wood. Though their edges are curved, all wood components are flat, all assembly joinery is at right angles and easily made that way by the square cross-secion of the foam batts, which act as gluing cleats.
27 comments
Nov 20, 2011. 11:19 PMindianabob says:
how about sewing a skin of heat shrink dacron then shrink it and put a good paint..might be an interesting concept,,, cheap too,,,,cheap is good
Aug 3, 2010. 11:24 PMmichaelhoover says:
im curious to know how the boat hull has held up over time. Is there any cracking or denting?
Jul 8, 2010. 11:55 AMScott39 says:
I would like to use this foamboat construction method to make me some outriggers for my canoe.
Jul 8, 2010. 3:35 PMScott39 says:
Thanks a lot unclesam, I will check it out. I have never played with fiberglass before, but I figure it can't be to hard.
Apr 22, 2010. 8:27 PMsdavisrt says:
I have a fiberglass boat that was stored with the hull facing up.  The gel coat now looks horrible and I want to paint it with something.  I have sanded the bottom so whatever I used would have a good surface to adhere to.  Does the latex paint hold up ok? This seems like a very economical way to make my boat look better. And I don’t mind if it has to be reapplied now and then.
Apr 24, 2010. 11:36 AMminipancho94 says:
if your gona go the cheap way instead of the better way that unclesam said, i wouldnt go with latex, it can get peeled off by the tape if your painting borders n stuff, also not all latex paints are water proof if any are. you can use latex but your gona need to water proof it.
May 16, 2010. 4:58 PMwhowild says:
Please do not use latex, if you can not get your hands on some gel coat then an automotive enamel will work well.  If you're just going to paint the bottom of your boat, a quart would probably do.
Apr 22, 2010. 4:48 PM652800 says:
Do you think that this type of construction will allow me to make a sunfish hull?
Oct 20, 2009. 5:35 PMJoshWC says:
ThanxLots Ive been shaping and wrecking foam for a while.
In my quest for 2 identicle hulls for single man powered fishing catamaran.
ILL send some deep water ocean fish
Thank You.JC
Nov 16, 2008. 3:54 AMPornostache says:
Is the hull hollow? what was your layup schedule?
May 4, 2008. 7:29 AMmac969 says:
I relly love your desigin it allow me to build a kayak in the easy way, but do you have a plan for kayak?i want to build a kayak but I have no plan for building a kayak from foam
Feb 14, 2008. 11:48 PMShinchan says:
Excellent! This gives me all kinds of ideas: a Hobie-type hull, power cat, foam outrigger canoe... Thankyou for posting.
Jun 20, 2007. 6:33 AMbroham says:
I want to use my old 10' jon boat for a mold (outside of boat ). I want to lay glass or kevlar over boat that has been treated with a release and copy about half of it (bow section). Then make a second copy of about half (bow section again) and join the two together, I now have a punt for shallow water work. How would I join the two halves together for the strongest bond?
Jun 21, 2007. 9:48 AMbroham says:
Hey thanks for your quick follow-up. I'll do as you suggested. I purchased plans for a 16' lapstrake row/power/sail called the "whisp" several years ago and never built it. I'm planning to make it out of foam and laminating it. Just started the learning curve building and working with foam. Thanks again for your help...bill
Jan 23, 2008. 5:56 AMJerobajas says:
For a smooth, yet stronger butt joint, insert rigid discs called "biscuits" , wooden dowels or even carbon fiber spars buried 50% into each of the sections being joined. The discs, or other planar form such as battens should be placed in plane within the pieces' joint. A ribbed structure, sort of like a wing layed over equal lengths of each section would be a very strong way to reinforce a two-piece boat, if enough ribs are used, and enough epoxy and glass roving goes on top of them. I've seen a nice design which made use of the interior volume of the "wing" in the bottom of the boat by placing waterproof hatchways through the fiberglass into the cells between the ribs, for handy storage of gear. This design was made to stow nested, and be joined only during use; a sort of "collapsible boat", and though I dislike that juxtaposition of words, the virtues of the concept are undeniable for cruising yacht tenders or cartop use.
Jun 17, 2007. 6:18 AMflywoodkb says:
Great work! I'm definitely going to try this on a small outrigger for a kite-powered boat. Thanks for posting it.
Jun 17, 2007. 1:50 AMpsychsurf says:
Wow, that's great! I do a lot of work with EPS in surfboards, and hotwire my own blanks from block foam, but have never considered using this kind of templating to get the kind of curves you are doing. That's some great outside-of-the-box thinking there! Makes me want to make a kayak or something. :)
Jun 16, 2007. 5:35 PMjoejoerowley says:
Wow!!!!!!!!!! That is really cool. I like that a lot. If I ever get in the boat making spirit I totally going to make this. Thanks
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
61
Author:unclesam
