3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Foamboat construction
Step 10Real deal, P05
Real deal, P05
P01 served its purpose to proof the FOAMBOAT concept, develop tools and working techniques, and to show that a mold built in this way is extremely strong and stiff because of the very thin pieces of plywood encapsulated within it at 90 degree angles to one another. A crust of fiberglass and epoxy would add even more strength. P01 turned out much bigger and heavier that I wanted for my original purpose, so I did not even fiberglass it. I realized I did not need the 1/2" thick plywood deck board for strength, which made up half the weight of the mold. The next hull I constructed was the streamlined P05, and I used the same thin marine plywood for the deck plate that I used for the other wood pieces. I glued four blocks of 3/4" plywood to the inside side of the deck plate, at two locations where I could screw through the deck of the finished fiberglassed hull and into the blocks to make attachments. I marked the locations of the blocks on the outside side of the deck, which could be seen through the deck's layer of fiberglass.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:unclesam
