3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Foamboat construction
Step 12P05, one mold and one finished
One finished mold and a twin after it has been fiberglassed and painted with white exterior latex house paint.
I will be glad to reply to comments and questions posted by interested folks who have first thoroughly studied this Instructable.
U. S.
6 comments
Aug 3, 2010. 11:24 PMmichaelhoover says:
im curious to know how the boat hull has held up over time. Is there any cracking or denting?
Apr 22, 2010. 8:27 PMsdavisrt says:
I have a fiberglass boat that was stored with the hull facing up.  The gel coat now looks horrible and I want to paint it with something.  I have sanded the bottom so whatever I used would have a good surface to adhere to.  Does the latex paint hold up ok? This seems like a very economical way to make my boat look better. And I don’t mind if it has to be reapplied now and then.
Apr 24, 2010. 11:36 AMminipancho94 says:
if your gona go the cheap way instead of the better way that unclesam said, i wouldnt go with latex, it can get peeled off by the tape if your painting borders n stuff, also not all latex paints are water proof if any are. you can use latex but your gona need to water proof it.
May 16, 2010. 4:58 PMwhowild says:
Please do not use latex, if you can not get your hands on some gel coat then an automotive enamel will work well.  If you're just going to paint the bottom of your boat, a quart would probably do.
Jun 20, 2007. 6:33 AMbroham says:
I want to use my old 10' jon boat for a mold (outside of boat ). I want to lay glass or kevlar over boat that has been treated with a release and copy about half of it (bow section). Then make a second copy of about half (bow section again) and join the two together, I now have a punt for shallow water work. How would I join the two halves together for the strongest bond?
Jun 21, 2007. 9:48 AMbroham says:
Hey thanks for your quick follow-up. I'll do as you suggested. I purchased plans for a 16' lapstrake row/power/sail called the "whisp" several years ago and never built it. I'm planning to make it out of foam and laminating it. Just started the learning curve building and working with foam. Thanks again for your help...bill
Jan 23, 2008. 5:56 AMJerobajas says:
For a smooth, yet stronger butt joint, insert rigid discs called "biscuits" , wooden dowels or even carbon fiber spars buried 50% into each of the sections being joined. The discs, or other planar form such as battens should be placed in plane within the pieces' joint. A ribbed structure, sort of like a wing layed over equal lengths of each section would be a very strong way to reinforce a two-piece boat, if enough ribs are used, and enough epoxy and glass roving goes on top of them. I've seen a nice design which made use of the interior volume of the "wing" in the bottom of the boat by placing waterproof hatchways through the fiberglass into the cells between the ribs, for handy storage of gear. This design was made to stow nested, and be joined only during use; a sort of "collapsible boat", and though I dislike that juxtaposition of words, the virtues of the concept are undeniable for cruising yacht tenders or cartop use.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:unclesam
