3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Foamboat construction
Step 5Vertical web attached
Vertical web, or keel, is glued in place, most of the glue area is provided by the foam batts. I joined pieces of plywood, very thin marine plywood in this case, using butt joints backed up by strips of the same wood. All gluing, wood-to-wood, foam-to-foam and wood to foam, was done using Titebond II, which is water-resistant, (III now available), from home centers, and which has long "open" time. The assembly process needs to be done one step at a time, with adequate time between steps to allow the glue to set fully.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:unclesam
