3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fog Chiller for Cheap Fog Machine
I purchased one of those cheap fog machines (30$) for Halloween this year. It works fine, and it even comes with an IR remote for stealthy operation! It did what it should, it spewed out some fog, but it was hardly as satisfying as I had hoped. The smoke dissipated quickly and didn't have a whole lot of substance to it. It was wispy, thin, and light, and I was starting to think to myself that I should have splurged on the more expensive model. Some reading on Google let me know that the secret to good thick billowy fog that clings is chilling it down. Blow the smoke over ice or dry ice. Well I cannot readily get my hands on dry ice, and initial tests of placing an ice pack in the path of the fog jet worked great. It really does improve the quality of the fog. I quickly set about looking through my junk bins to slap together a cheap chiller. I am pleased with the results.
Step 1Gather your junk
Gather your junk
There are only two key components for this project, and even those are flexible.
You will need :
-Something that will serve as a cooling chamber. (I used an old cooler, you need something that can withstand the ice and the heat of the fog)
-Something to direct the fog safely from the nozzle of the machine into your cooling chamber. (The thing to remember here is that fog machines get hot. I used 1.5 inch Diameter PVC pipe.)
9 comments
Oct 26, 2011. 6:56 PMjuice1971 says:
Hi Everyone, i've been reviewing all these fog chiller ideas and I love them all. One question though, all designs involve cutting one hole high and the other low for the fog to seep out. If I wanted to use the indoors I'd be worried about the ice melting and water going all over the floor. I am wondering if you could direct the fog to the bottom of the cooler and then back up to the top somehow ( perhaps with PVC) so you would have a resevoir for the water to collect in.
Anyone have any ideas to share. It important because in my particular setup, my fog machine would be near some lighting and sound and I can't afford any electrical issues or shorts.
Thanks for your thoughts.
Oct 26, 2011. 7:05 PMjuice1971 says:
Also what if I drilled the holes near the top instead of the bottom - anyone try that?
Oct 23, 2011. 8:39 AMTOCO says:
I have made ones like this and they worked great for my fog machine from menards for $14. But the cheap fog machine burned out and stopped working. So the day after halloween a couple years ago I bought the one from target with a built in fog chiller. But the ice compartment is so small and if you fill it all the way the fog doesnt come out. So this year I am going to try a few small pieces of dry ice at a time.
Oct 22, 2011. 1:11 PMryaneaton88 says:
Cool way to do it! Made mine today, Works great!
Oct 20, 2011. 7:48 PMkhendar says:
I think its worth pointing out that there are two types of machines for making "fog". There's chilled fog machines, which use dry ice or niquid nitrogen, plus water to create ground-hugging fog, and there are heated fog machines, or smoke machines, which use mineral oil heated to a vapour. Fog machines tend to produce fog which hangs around longer, whereas heated smoke machines tend to dissipate faster.
It looks like you've created a kind of hybrid of the two, a mineral oil smoke machine with a chamber to cool the smoke to prevent it dissipating as quickly.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
47
Author:fjordcarver
Dad, maker, dreamer, hacker, painter.
