Foldable/Portable Superlight Doggy Water Bowl $0
This is a bowl designed for giving your dog water when you take them with you to the park, or to the trails. The opening of the bowl is narrower than the base, so the pressure of the water in the bowl holds the bowl upright. You can fold it up and put it into your pocket when you are not using it.
You could go buy a foldable (and prettier) portable dog water bowl for $10-$15 or you could make one in less than 30 minutes and do some recycling too.
Step 1: Materials and Tools
Picture of Materials and Tools
You need the following materials:
Flexible Plastic Sheet at least 28cm x 28cm
Aluminum foil
Piece of scrap wood
I am using some housewrap that I got from the throwaway pile at at local construction site. It feels like fabric; is light, watertight, and strong. It is used in the same way that Tyvek is. (I do not know if Tyvek would work for this project).
And the following tools:
Ruler
Scissors
Soldering Iron
Marker
Clamp
Step 3: Plastic Welding
Do this outside, unless you like toxic fumes.
1. Heat the soldering iron
2. Place aluminum foil over the area to be welded together.
3. Move the iron over the area where you wish to make your joint, melting the pieces together.
I use the clamp to hold my piece of scrap wood which is my welding surface.
Practice on some scrap pieces. Use the flat side of your soldering tip. Also fold the Foil in half in order to minimize the chance of fouling the soldering iron with melted plastic.
That is the basic technique. Now we start by tacking corners.
HAL 90005 years ago
This is great, i'll have to make one for my girlfriend's dog. i make little stuff-sacks out of the tyvek mailing envelopes our paychecks come in, i'll post an instructable friday. im sure tyvek would work, as its used as housewrap and is watertight. oh, and grats about the newsweek thing!
nugget659 (author)  HAL 90005 years ago
Hey post a link to the tyvek stuff sack instructable when you make it. I am glad you like this.
Patented5 years ago
Why am I a collaborator to this instructables?
Flumpkins5 years ago
awesome!!!!!!!!!
5/5 and fave
Gjdj35 years ago
Hey. Did you know that you were in June 16th issue of Newsweek! It's on page 53 under the pets column! Congrats!
nugget659 (author)  Gjdj35 years ago
Wow, that is pretty neat. I am surprised. Thanks a bunch for letting me know.
Gjdj3 nugget6595 years ago
Yeah. I was excited to see instructables in the press again. I bet you get a whole bunch of traffic to this instructable now. Newsweek has loads of readers.
You know I never expected this instructable to get any attention. This is neat. +1 for recycling/dumpster diving.
This is so cool!!!
lemonie6 years ago
Nice work. Also, this has more potential uses than watering dogs. L
nugget659 (author)  lemonie6 years ago
Thanks for the feedback guys. The bowl is holding up well. The dog loves it. @ Graham, thanks for the baking sheet tip. Don't have any now though.
Nice project. Silicon baking sheet is also good for forming welds through and it never sticks.
gmoon6 years ago
This is a 'classic' project, and makes a great instructable! You can actually boil water in a paper bowl similar to this...
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
