Folding Wooden Stepladder
I made this wooden stepladder based on some plans I found online.
I didn't follow the plans very closely (my bolts and dimensions were different) - I just used the general layout of the stepladder as a guide.
This was the first project I've made using a tablesaw. You could make this stepladder with a circular saw or even a handsaw, but I found the tablesaw made precision cuts really easy.
In this instructable I also describe how to use a router to make dado joints and consistent curved corners.
Step 1Materials
Materials
You'll need a sufficient quantity of reasonable quality wood - I used about 7 planks of white pine, measuring 90 x 20 x 900 mm
Hardware:
8 x M8 carriage bolts, about 55 mm long
8 x M8 washers
8 x M8 lock washers
I used carriage bolts which have a large dome head, this means you only need a washer on the end with the nut.
The lock washers are needed because the bolt are inside a moving joint. Without the lock washers the nuts would gradually undo themselves.
M6 bolts would have worked fine too.
11 comments
Sep 10, 2011. 5:45 AMLorddrake says:
great job.
have you had any problem with your 3mm spacer screws from step 12 wearing into the underside of the ladder top?
Do you think that some of the felt or rubber peel and stick feet would work instead of the screw heads?
not sure if i described what i was thinking of very well so here is a link to some i found online to give you an idea ..feet
Sep 10, 2011. 9:28 AMsmirnov55500 says:
It simply and simultaneously a high class! I wish to make for a long time same. Thanks.
Mar 12, 2011. 5:41 PMJon316 says:
when you are cutting the wood,what can you do to prevent or lessen the splintering of the wood.
Sep 10, 2011. 1:09 AMJayefuu says:
A zero clearance insert would help with this
Mar 13, 2011. 8:12 PMJon316 says:
Same goes with the miter saw and table saw
Feb 28, 2011. 9:04 AMnullandvoid says:
awesome work ill have to make one seeing as my shop is always in need of another small stepladder and i see ur table with the vodka bottles! im gonna be making a coffee table with jaeger bottles and such as the tabletop when im finally done working for uncle sam who btw is the worst uncle ever! lol
Sep 29, 2010. 8:25 AMjeffeb3 says:
I'm a real rookie at finishing, but when I last tried poly with foam brushes, I ended up with a lot of bubbles. I found some water based poly, and it's a lot easier to wash out of the brushes.
Sep 2, 2010. 11:06 AMCreativeman says:
Beautiful work, pipe 42!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:pipe42(Pacific Empire)
