Food Masher/Large Wooden Pestle
This is a simple kitchen device for mashing, crushing, pounding, and mixing food. I asked my father to make one  when I was about seven to help me mix up frozen cans of juice and over the years it has proved to be very useful.
Step 1Get a stick
Get a stick
The stick should be fairly straight, at least 3 inches wide at it's narrowest point, at least 16 inches long, and hardwood.
To find out if your stick is hardwood press the tip of your fingernail into the wood. If your nail leaves a large dent then the wood is not hard enough.
I found my stick at the beach. There is no reason that you couldn't buy a stick, but why should you when wood grows on trees?
If you choose to use "green" wood (wood that has recently been cut off a living tree and is still wet) the wood may crack.
To prevent cracking let your wood dry slowly by dripping hot wax into the ends of the stick and/or storing it in a plastic bag and/or the freezer when you are not working on it. If your piece of wood starts cracking you may be able to undo some damage by sprinkling water over the crack and microwaving it. Do not put wood in the microwave for more than 20 seconds at a time. Let the wood cool off before putting it back in the microwave.
14 comments
Dec 2, 2007. 10:52 PMSlothOnSpeed says:
I know that this is a rather old Instructable, but I'd be rather concerned about where I picked up any old stick to make into my pestle. Be careful not to use any sort of pressure treated wood to make anything that prepares or has contact with food. Otherwise, what a fun Instructable!
Jul 26, 2007. 9:30 AMHamO says:
Well done, thanks for sharing.
Mar 30, 2007. 11:04 AMMarcos says:
Mineral oil is best! Vegetable oils will not only get rancid, but stick as well. I oil all of my wooden spoons and wooden handled spatulas, etc. a couple of times a year. (most years ;-)
Oct 14, 2006. 7:57 PMatraeyu says:
That's awesome! But I don't have a lathe ... maybe some day ...
Mar 18, 2007. 10:40 PMMrShifty says:
Jan 19, 2007. 8:12 AMFrank in Virginia says:
Very nice posting. I'm a collector of mortars and pestles and just getting started making my own. Your instructions are very helpful.
Jan 17, 2007. 4:13 PMthehatman says:
Olive oil or salad oil workks great and doesn't get rancid
Oct 10, 2006. 12:07 AMChaseandPhyllis says:
Garlic rosemary mashed potatoes and some mahi-mahi? See you on the Kona Coast.
Sep 15, 2006. 2:28 PMFibreway says:
30 grit !!!! Holt sh*t man what were you cutting the wood with, a screwdriver?
With a nice sharp chisel even 120 grit would roughen the finished surface. If you're *really* good ( which I'm not ) you don't need to sand it. I also suggest that you use a proper woodturning lathe, engineering lathes and tools really don't work for wood.
Traditionally this sort of thing was made from sycamore wood because it has a nice light colour. Sunflower oil makes a nice finish in my experience
Aug 17, 2006. 9:34 PMGENIUSMAXX says:
I often carve spoons from hardwood and find that mineral oil [which can be found at any grocery or drug store (it's a laxative when ingested in large amounts)] makes a much nicer sealer and does not spoil like vegetable oil is want to do.
Aug 17, 2006. 9:35 PMGENIUSMAXX says:
weird, why did that hyperlink....
Aug 21, 2006. 10:51 AMleahculver says:
Square brackets create hyperlinks. - leah
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:jesse.hensel(Jesse Hensel's Artwork)
Perhaps I am the heretical harbinger of the New Archaic, perhaps I just like wood.
