If you have ever drilled acrylic with a standard twist drill you've probably noticed that it is less than ideal. The angle is too shallow and the drill bit tends to break out the backside and chip the material. Here is an easy way to put a much steeper angle on the bit that leaves both flutes the same length (on center) and gives you a ridiculously sharp edge (where it counts).
Disclaimer:
- I am about to show you a few things that are definately not safe / OSHA approved.
Try this at your own risk.
If you blow up a grinding wheel or burn yourself or in any other way damage yourself, anyone else or your tools or equipment, you've been WARNED!!!
So anyone who feels like leaving safety related comments, please leave them only if you have a safer way of doing this. I already know it is dangerous.
That being said...On to the show!
Remove these ads by
Signing UpStep 1Tools needed...
The drill bit you want sharpened (of course)
A small (high speed preferably) electric hand drill
A bench or pedestal grinder
As for a safer way, I used to have a trailer bearing that fit on the keyed Jacobs chuck of the black and decker I have ( green body too,,,) that allowed me to grab the chuck with some amount of safety ( it had a wide press fit race)
If you need a larger hole than you have a twist drill for, a spade or paddle bit will also work. It however does not leave such a smooth finish inside the hole; but a small drum sander on a "Dremel" type tool can solve that. Also the spade bits with "spurs" on them work better than the flat ones.
Concerning the temper in drill bits: They should be hardened (from the factory) that's why they will shatter or snap rather than bend. If you grind slowly (lightly) and don't burn (blacken the steel) you will be just fine.
Thanks for the comments!
Mikey
I'd like to see the "burr" to which you are referring. Cabinet makers put a burr on a flat (or sometimes curved) piece fo steel and call it a cabinet scraper. It leaves an exceptionally fine finish that needs little or no sanading.
Thank you for the comments
Mikey
less angle fiberglass dulls bits fast
learned this method 20 years ago
works great is it safe yes as long as
you not a total goofball
