3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Foot Flusher
Step 2The paper towel rolls
Lets first work on the paper towel rolls because most likely, you will want to paint them so they look nice in your bathroom next to your toilet. (Note: Technically you do not have to use paper towel rolls. You can use a hollowed out broom stick, shower curtain rod or whatever you may have depending on your ambition. I like the rolls because theyre cheap, easy, and paintable - however, you technically don't have to use ANYTHING, as the only purpose this serves is to hide the hanger. If you don't care that the hanger is visible then forget about this step and move on).
Assuming you do not want the wire hanger to show, you're going to want to cover it up with something nice. Take the two paper towel rolls and shove them into eachother so you have one long tube. Squeezing it and mishaping it is fine, and you can technically glue it on the inside for extra support, but you don't have to as the spray paint is sticky and when drying will stick them together.
Do this step first as the spray paint needs time to dry and will require numerous coats - but each coat must dry before spraying a new one. This whole process will take maybe an hour, but you can do other thinsg while waiting for it to dry.
SPRAY PAINT IS DANGEROUS! Only use it if you are an adult and know how.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:reykjavik
