Foot-on-pedal / True Bypass crybaby wah mod by KoenB
UPDATE: The old wiring diagram contained errors (sorry, I wasn't too familiar with electronics and wiring diagrams, this was one of my first projects and my first instructable). There were also questions about the blue wires going to the wah pot, I drew the wah pot to make things clear.
This makes your Crybaby wah switch on when you put your foot on it, and turn off when you remove your foot!. It will also be equipped with true bypass. That means that the circuit is actually bypassed when the wah effect is off, instead of passing through its transistor bypass circuit (that ruins your sound, removes clarity, makes distortion sound like a bad fart, etc).
If you might want to control your wah the original way for some reason, then there's a miniswitch on the side that lets you choose between the two modes. When the wah is in foot-on-pedal mode, a green led lights up to indicate this. I also placed a red led that indicates that the wah is on AND in original mode. The thing I hated most about the standard crybaby is that you could not see whether it was on or not!
-- VIDEO --
Step 1: Buy parts
You have to buy a few parts for this mod. I bought them all together for about 10-15 euro's:
- 3PDT stomp switch, to replace the stock one
- green 3mm LED
- red 3mm LED
- 350 ohm resistor*
- 390 ohm resistor*
- 3PDT miniswitch
- DPDT mini momentary switch, with button.
- thin electrical wire
- superglue or two led holders
Tools you (might) need
- plyers, for cutting the wires and tightening the nuts
- a wire stripper. You can use the plyers if you dont have one, but be careful not to cut the wire
- a drill and a set of drill bits
- soldering iron
- screwdriver
*If you can't find these specific resistor values, take the the nearest value you can find. A higher value is good, but don't get significantly lower because that will cause the LED to burn out. Also, if you think the LED's are too bright, try higher value resistors such as 1K or higher.
lsalles says: Mar 10, 2011. 10:01 PM
In this diagram, can I withdraw the buffer components or this is not necessary and that will be true bypass even with the buffer there?
Thanks, bro!
KoenB (author) says: Mar 12, 2011. 4:15 AM
I believe the buffer circuit is also bypassed, but i'm not a 100% sure. You can test it by plugging in the wah with out power and turning it on and off. If it really is true bypass, you'll still be able to hear sound coming out of the amp when the wah is turned off.
Fopat says: Oct 5, 2010. 4:58 AM
Thanks for this mod! The momentary switch to enable the wah is a very good idea!
However, I think one step is missing to make the mod really true-bypass. From what I have read on the 2 websites below, to be true bypass, the circuit between the input jack and the buffer input needs to be cut:
http://www.geofex.com/Article_Folders/bypass/bypass.htm
http://www.stinkfoot.se/andreas/diy/mods/dunlop.htm
Else, the green cable soldered on the capacitor has no use. Or maybe I misunderstood something?
mtstreit says: Jul 24, 2010. 10:14 AM
can you use 5mm LED lights instead of a 3mm LED?
rpdiggs says: Jan 22, 2010. 9:24 AM
I found this mini momentary DPDT switch for the US..  Certainly hard to find.  Haven't ordered it yet but think it's my best option.
http://shop.willyselectronics.com/browse.cfm/switches/snap-action/miniature/30-2750--mini-snap-action-pushbutton-momentary-dpdt-1a-125v-solder/4,4768.html
barkley says: Jan 7, 2010. 8:49 PM
Where can I find a DPDT mini momentary switch?
Ive looked everywhere!
The site mentioned by somerockerguy doesnt have them and niether does that dutch one you mentioned!
KoenB (author) says: Jan 9, 2010. 6:08 AM
My local electronics shop sells them, but i dont know where they get them from (an they probably wont tell me). I tried a bit of googling using the image search and found this after a while https://www.photonage.com.au/new-c-71_39.html?page=1008&sort=20a
KoenB (author) says: Jan 9, 2010. 6:10 AM
... i dont know if theyre shipping worldwide though..
ludoheavy says: Oct 20, 2009. 12:14 AM
tank you for the new diagram!!
But i have the same question of Link0126, where goes the blue wire from the harness?
KoenB (author) says: Oct 20, 2009. 4:21 AM
I can image this being confusing. I'll update the schematic again to make it clear. It should be up in under an hour.
stupidityisagift says: Jul 12, 2009. 9:47 AM
can u do this to a modded cry baby that has been modded as a wah/volume pedal?
KoenB (author) says: Jul 12, 2009. 12:31 PM
Not 100% sure but i think it will work. All the volume pedal mod does is removing one capacitor, no major circuit changes, so it will probably work.
lainage says: Jun 24, 2009. 10:20 AM
Can you post a link to the mini-momentary switch supplier? I cannot find a mini one anywhere. Awesome mod by the way.
KoenB (author) says: Jun 24, 2009. 12:46 PM
I bought it at my local electronics shop here in town. I dont really know any online suppliers, maybe google can help you ;)
go2ldook says: Apr 23, 2009. 8:16 PM
Your wiring schematic is wrong in terms of the momentary switch. Here is how it should go:
4 5 6 (looking at lugs with the common to left, normally closed to right.
1 2 3 and lugs numbered as shown)
C NO NC
1= Purple wire (Output to amp, to middle lug of middle row on 3pdt switch)
2= Blue wire (The effect loop return, goes to wah pot)
3= Green wire (Input from guitar, goes to the PCB harness)
4= Green wire (The effect loop input, goes to top right lug of the 3pdt switch)
5= Solder your jumper wire from 5 to 3)
6= No wire here
With this arrangement the switch (as long as it is the same type of momentary switch with the same C-NO-NC orientation as shown in the drawings in the instructable) should work as expected.
As drawn in the instructable the wiring diagram results in no signal with foot off (C-NC connected, which as drawn means the guitar input flows to the effect loop return). With the Foot On you get Clean (C-NO connected, the guitar input connects to the amp output). At least this is what I see...I had wired it as shown in the instructable, and posted stating that I had no signal foot off, and wah with foot on, but I may have been frustrated at the time and wrote the wrong thing...if you follow the signal paths, foot on should give you a clean signal as it is currently diagrammed.
Also, for other who know nothing about these switches, the lug are flat. To orient the 3PDT stomp switch and 3PDT mini toggle switch correctly for wiring as shown in the instructable, the lugs should look like this:
I I I ON _ _ _ ON
I I I for the stomp, but like this: _ _ _ for the mini switch.
I I I _ _ _
I think that is correct for all stomp switches. For the mini 3PDT toggle, you just need to make sure the "ON" throws are on the left and right as shown.
Sorry to be so verbose, but I am not an electronics hobbyist, so having this spelled out in the instructions would have saved me a lot of pain. No offense to the author...this is a cool project, and thanks for posting it!
go2ldook says: Apr 23, 2009. 8:18 PM
Sorry, my attempt at drawing a schematic for the 3PDT switches failed when it got reoriented at posting! Hopefully people get the idea.
go2ldook says: Apr 21, 2009. 9:20 PM
Have wired this up and checked over it numerous times. My LED's light fine. With the momentary switch I get no bypassed signal, but when I depress it I get the wah. If I switch back to standard switching, I get the wah effect whether the switch is turned on or off. Can't figure this out. The two wires that go to the pot...do they go to the same lug on the pot that the blue wire to the PCB goes to? Any ideas what I have done wrong?
link0126 says: Mar 25, 2009. 1:12 PM
do the two blue wires coming from the wah pot indicate the one wire from the pot as well as the other one coming from the harness? does it matter which one goes on which switch? thanks
link0126 says: Mar 24, 2009. 9:17 PM
how do you mount the momentary switch without a nut on the top?
KoenB (author) says: Mar 25, 2009. 3:46 AM
There is a nut but its 'submerged' in the rubber pad so you cant see it. I chopped away a little bit of rubber with a drill bit (i believe it was 7 mm) and pushed the nut in the hole. Be careful not to drill the metal because and ruin the hole for the switch post. Then i grabbed the switch and screwed it in from beneath (turning the switch, not the nut)
greatnameless1 says: Mar 16, 2009. 8:46 AM
I'm just saying, why? Instead of going to all this trouble, don't buy a crybaby in the first place! Get a Weeping Demon - They sound great, they already do this, they're spring loaded, they're customizable, and they're built to withstand armageddon. Better than spending your money buying replacement crybabies..
mikka1984 says: Feb 23, 2009. 7:27 AM
hey, i am doing you wah pedal mod at the moment and a bit stuck the wiring is correct as far as i can see, i checked and rechecked it and it all seems fine the issue i get is kinda loud constant crackling sounds and i can barely hear the giutar through that i got a few questions 1st does it matter which way i wire the switches ( i know where the middle is but not sure if its the same if i wire it if i turn it on the other side ie mirror( 2nd on the wiring diagramon the wah circuit board u have a comment solder to capacitor lead. i soldered the wire from the back of the board so the wire would be out of the way, is that correct? 3rd once i removed the blue wire to the stomp switch i get a blue wire that leads to wah pot and to the circuit borad. amd i suposed to keep this way or should i omit the blue wire that come from the circuit board? thanks for your help
mikka1984 says: Feb 23, 2009. 4:16 PM
ok just a quick update
after fiddling with it for about 3 hours (unsoldered it and soldered it back all together) same result, when i plug it in loud crackling sounds and i can barely hear my guitar throught it. thats the same effect with all positions of stomp switch and 3pdt switch. also noticed another thing... the leds dont turn off completely when i change it, the light dimmers but it still on on both :(
im getting whipple wah mod in a few days so im gonna try trouble shoot then by 1st converting it back to original state and see if i can solve the problem then, but at the moment .... no joy :(
mikka1984 says: Feb 23, 2009. 5:28 PM
another quick update just removed the 3 switches and leds and installed the old stop switch in the pedal... al works find, very confusing rechecked the wiring again, everyhing seemes to be correct tested all switches, all work perfectly im getting a little bit angry now
KoenB (author) says: Feb 24, 2009. 3:40 AM
Man this is weird. It sounds like a bit of a shortcut, since the leds stay on all the time (sort of). Can you send me some pictures of the wiring? Maybe it makes some sense. My email is Koen_bussemaker@hotmail.com. Did you get any good results with just installing the 3DPT stomp switch (so in fact just adding a basic true bypass mod) ?
mikka1984 says: Feb 24, 2009. 6:05 AM
ok email sent, thanx for your help :D i will host the original size images this evening
KoenB (author) says: Feb 24, 2009. 11:24 AM
Have you tried putting the circuit back in the housing? A lot of pedals use the metal housing as a ground lead. This might be the problem. If not let me know
mikka1984 says: Feb 24, 2009. 5:43 PM
check ur email :)
itsachen says: Aug 1, 2008. 2:27 PM
hey dude, love the instructable first of all where do u get ur 3PDT switches? i cant find any in my local radioshack, only online... thanks
somerockenguy says: Oct 18, 2008. 7:10 PM
i got mine here there based in the U.S. and they have all the parts to do this mod. http://cascadesurplus.com./
KoenB (author) says: Aug 1, 2008. 3:34 PM
I bought mine online at www.newtone-online.nl/catalog . Great shop, but a dutch one, so probably not your thing. 3PDT switches are hard to find, so I guess you have to order them online.
vitorp07 says: Aug 20, 2008. 12:18 PM
Hi,nice project and thanks for sharing it. i just have a question,could you help me out or pointing me to find a DPDT mini momentary switch,i just can't find one that seem to do the job if you have a link for ebay or something online it will be much appreciated. THANKS
KoenB (author) says: Aug 20, 2008. 12:31 PM
I got mine from a local shop here in Holland. But since you're probably not dutch, you have to find a different shop (obviously). http://shop.willyselectronics.com/browse.cfm/4,4768.html I found this one by google. Yes, they are expensive. Mine was 5 euro's.
vitorp07 says: Aug 20, 2008. 9:59 PM
Hey thanks,they don't ship out of USA and i live in Canada but i sent them an email asking if they could sell me that switch,i hope they can...
KoenB (author) says: Aug 21, 2008. 4:06 AM
And if they don't, try this one http://www.altronics.com.au/index.asp?area=prod&grp=373&pg=0&list=1
I think they ship worldwide, not sure though.
somerockenguy says: Jul 14, 2008. 12:52 PM
i finished you mod today it took about 4 hours. i am very happy with it i just need a diffrent momentary switch because mine is so high and makes poping noises.
here are pictures
http://tinypic.com/view.php?pic=2rm2tg6&s=4
http://tinypic.com/view.php?pic=dy64p&s=4
http://tinypic.com/view.php?pic=xfrgoz&s=4
http://tinypic.com/view.php?pic=25k6gjn&s=4
http://tinypic.com/view.php?pic=uvatd&s=4
http://tinypic.com/view.php?pic=312jqmc&s=4
http://tinypic.com/view.php?pic=2l8c001&s=4
if you want to use any of these pics you may.
KoenB (author) says: Jul 15, 2008. 4:16 AM
Looks nice! But I see you've used a big momentary switch. Try to find a momentary miniswitch, they are much smaller (and they pop less). These have small plastic shafts, so you can cut a bit off if you think its too high. I don't know if its a good idea to use your pics too. It might get a bit confusing with the different switches. And I am too lazy to add them too ;)
somerockenguy says: Jul 15, 2008. 8:57 AM
the site i bought every thing from only had the one momentary switch so im stuck with it un till i find some place localy that carrys them.
modmaniac says: Jul 10, 2008. 12:49 PM
Thanks, And, great instructions and diagrams. Best on the net!
modmaniac says: Jul 10, 2008. 8:17 AM
In your parts list you have the momentary switched specified as a 3pdt and the mini toggle as a dpdt but in your wiring diagram you show the toggle as a 3pdt and the momentary switch as a dpdt. I'm guessing that the diagram is correct and the parts list is wrong. It that the case?
KoenB (author) says: Jul 10, 2008. 11:33 AM
Yes, that was the case. Thanks! It's been corrected now. So you need a 3DPT miniswitch and a DPDT momentary.
somerockenguy says: Jun 21, 2008. 2:35 PM
For the 350 ohm resistor would a 10 watt 350 ohm resistor with 10% tolerance work and for the 390 would a 1/8 watt 390 ohm resistor with 5% tolerance work? These are the only 350 ohm and 390 ohm resistors i could find.
KoenB (author) says: Jun 22, 2008. 2:26 AM
Yeah they will work. The Wattage and tolerance doesn't matter at all in this case.
somerockenguy says: Jun 22, 2008. 6:36 AM
good then ill be building this in about a week when my shipment of parts arive.
KoenB (author) says: Jun 22, 2008. 8:08 AM
Cool that you're going to do my mod! Can you post some picture links when you're done ?
somerockenguy says: Jun 22, 2008. 10:30 AM
shure. any thing you want in particular? if you need pics for the steps ill be happy to give them to you if you want them. i wont be done for about a week i just ordered the parts. those 3pdt pushbuttons are not easy to find.
KoenB (author) says: Jun 22, 2008. 11:21 AM
Not anything in particular, just wondering how your mod will look ;) I ordered my 3pdt at newtone-online.nl, but thats in Holland. They are really hard to find!
somerockenguy says: Jun 30, 2008. 7:40 PM
the guy im ordering the parts from forgot to order the parts from a supplyer on two ocasions so to day he said he has every thing in stock ill order tha parts tomorrow and im going on vacation from the 5th to the 12th so i hope the parts will be here by then and i sould be done by the 13th. this is taking longer than i hoped but if all goes well and i don't cover the wah board in solder ill have happily compleated you instructable.
KoenB (author) says: Jul 1, 2008. 2:48 AM
Damn suppliers lol. They always cause trouble. I'm waiting for a fretboard I've order two weeks ago, assuming it would be here in a few days. But no. Looking forward to see your result. And have fun on holiday !
James Haskin says: Jun 12, 2008. 4:32 PM
I personally would not go through that much trouble for how I switch the pedal on and off, but thats just me. I'm more concerned with the sound. True bypass- awesome Funky triple switch madness n whatnot- verging on overkill
James Haskin says: Jun 19, 2008. 9:09 PM
I didn't see your video last time. Looks like it works really well. Point5mt made got me thinking about it, Does it sometimes cut out when you don't want it to? Great job but I'd like to see more pics :]
KoenB (author) says: Jun 20, 2008. 8:23 AM
It never cuts out. I've used it a lot and I've never had that problem. The switch is pretty sensitive so it turns on very quickly, even with a light touch of my foot ;) I dont have a camera here at the moment, so no extra pics for a while. Why would you like extra pics? There's not much to see ;)
somerockenguy says: Jun 21, 2008. 10:47 AM
the on thing missing is pics of the inside. it ywould be helpful to go along with the diagram for the wiring.
KoenB (author) says: Jun 21, 2008. 11:28 AM
Believe me, I've taken some pics... it's a big spaghetti of wires, it won't be helpful at all...
James Haskin says: Jun 20, 2008. 9:46 AM
I mean in future projects
somerockenguy says: Jun 21, 2008. 8:49 AM
for the 3pdt toggle switch is do you use an on-on or a on-off-on?
KoenB (author) says: Jun 21, 2008. 10:00 AM
Its an ON-ON switch. If you would use ON-OFF-ON, you would hear buzz (like you plug a guitar cable into your amp but not into a guitar)
somerockenguy says: Jun 21, 2008. 10:45 AM
o thanks that was the one part i was wondering about
point5MT says: Jun 14, 2008. 11:45 PM
great instructable, nothing overkill about it I sent mine into Keely to get the true bypass, and i swear ill never be able to play a wah again with out it. I like your foot on mod, would be nice to see the switch somewhere else, like on the hinge.
gmoon says: Jun 12, 2008. 12:43 PM
Nice! Good project, well documented. (I don't intend to mod my old pedal, but I might pickup another someday...)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
