Step 2Replacing the original switch
Now, cut the wires coming from the stomp switch. Cut them close to the lugs, we still need these wires! Now, remove the switch (use plyers to unscrew the nut).
Put in the new switch, and test it by kicking down the pedal. You should hear it click when you apply firm amount of pressure. Adjust the height with the nut and washers to get it working. You don't want to have to apply 10 tons of pressure on the wah to turn it on, but on the other hand, you don't want your wah to switch off when you just press the pedal down right? Fiddle around a bit and find out what works best for you.
Add Comment
